1994 Mild Restoration / Floor Repair (w/ Pics)
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#1 | |
Alright so I'm not entirely done with this project. But I'll keep ya up date.
Basically I started this like everyone else after I pulled up the drivers carpeting, the passenger is fine. There were several obstacles I had to deal with along the way. 1. I didnt know how to weld 2. I didnt have time to learn right now 3. I didnt know anyone who knows how to weld. So i decided on using Fiberglass, which according to several sources is pound for pound 5x stronger than steel. Heres the process: Step 1: Look at all the ungodly rust, I still don't know how I didnt fall through. http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0528.jpg http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0529.jpg Step 2: Start cutting out the rusted metal using a dremel and cut off wheels (the following pic is after 20, I used 7 more to get it to the second.) http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0531.jpg http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0532.jpg Step 3: Admire your work, read paper on the garage floor. http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0533.jpg http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0534.jpg Step 4: Make a template out of a paper bag. http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0535.jpg Step 5: Lay template onto green flower foam to make a mold. http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0537.jpg Step 6: Cut and sand the mold to make a proper shape. Cover with Wax Paper prior to fiberglassing. Step 7: Follow Directions on Fiberglassing kit, and lay in first layer http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0538.jpg http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0539.jpg Step 8: Remove Foam Mold Step 9: Sand down any inperfections using 60 then 100 grit sandpaper. Step 10: Seal the underside using a silicon gel http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0542.jpg Step 11: Add a couple more layers of Fiberglass for strength. Add metal mesh for structural integrity. http://i209.photobucket.com/albums/bb235/D0ntTr3ad0nM3/DSCN0543.jpg (Yet to be done) Step 12: Cut fiberglass edges and cover entire area w/ body filler. Step 13: Herculine and done.
-Jeff "JR" '94 CYTJ...its got a little of everything
Malo Mori Quam Feodari- Death Before Dishonor Never take life seriously. Nobody gets out alive anyway. |
#2 |
Free clues & suggestions
Step 14: Drink beer.
![]() Looks like it'll be nice when all is said & done. |
#3 |
Yea, for the 21+ group, I forgot to mention the 2-24 packs of Pepsi that was consumed.
Update: Got most of the body filler on, it was so much easier than the guessing I had to do for the Resin. Just have to do the edges and sand after work today. Then i can get started on the herculining. By the way, if anyone is reading this and saying to themself "Well I have no experience with Fiberglass I can't do this", I'd like to mention that this is my first time working w/ fiberglass or Bondo, and if you can do Bondo, you can do Fiberglass with some patience, and lots of rubber gloves.
#4 |
Nice writeup! My floor isn't quite that bad, but I'll have to tackle it sometime this summer. I never even would have thought of using fiberglass.
#5 |
Fiberglass ? New idea I am curious if it will work and not crack. Looks good. I just did my floor on my 94. It was funny to me that the driver side was rusted out but not the passenger side on mine, yours too?
#6 | |
Click Free
JF'er with a Theme Song Member #1 http://www.youtube.com/watch?v=MNzZzsvOClc His: 2009 Dodge Charger R/T- MOPAR CAI, vinyls by RiderGraphix, tinted windows, red painted calipers. 1986 Trans Am- Rebuild underway. Hers: 2003 Grand Cherokee Laredo-4.7 V-8, Leather, Power Everything, Factory Tow and Recovery Points, KOR 2.5" BB, RE Monotube Shocks, Maxxis Bighorns, Kolak 3" Exhaust. Gone, But Not Forgotten: 1994 Wrangler YJ- Too many mods, not enough money! |
#7 | |
#8 | |
Nothing really new, several manufacturers have been making CJ tubs entirely out of fiberglass for years. To the OP: Make sure you dont put tons of bondo on there, it really should only be used to fill in the low spots in your 'glass. If possible, avoid going more than 1/8" thick covering of bondo over the entire surface. I would hate to hear how the rest of your floor pans rusted from the inside out because of trapped water seeping into any cracks.
#9 |
Jeeples, Thank you for the reply. I was refering to a repair over steel for a floor to fix rust in a spot that takes a beating this is new to me. Has that been done many times b4? Is this a good repair for me to keep in mind?
#10 |
looks like you did a nice job. fyi tho if you really wanted an easy fix for that you could buy a replacement floor board, trim and clean and just JB weld it to the tub. we did this on a friends trail jeep and has held up remarkably
"We'll get out of this disaster in time for the next one" "I'm done recomboobulating the energy-mo-tron" 88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff |
#11 |
Jeeples Thanks for the click free. Btw with the bondo, ive been doing it kind of thin, but im planning on putting herculine over the top, would I still have to worry about water? I agree having other stuff rust out is going to stink. I'm going to be tackling the "Jeep" logo rust spot on the outside, and a spot on the fender next.
Pasin- So far I've had myself (~170) and about 100 pounds of free weights, and havent so much as heard even a creaking noise out of the floor. I'll keep this updated if problems arise, so far so good. Ovrlnd- I thought about that, but decided against it because this is my DD and wanted to get somethign I was confident in.
#12 |
Dang, I thought mine was bad! We just cut out the rot and welded in a new pan from Quadratec. Painted the underside with undercoating, hit the top side with some paint. Just need to find someone to weld the passenger side for me. If I could get that done this summer, I can start thinking about lining the tub.
His : 1992 YJ (Almighty 4 banger) Hers: 2004 WJ Columbia Edition (4.7HO) Black Jeep Society - Black Jeep Club V2.0 #37 - Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
#13 |
So i got most of the bondo on today, just got a little bit more around the edges. The only complaint I have about this whole project so far is the AWFUL smell that goes with it.
I guess I never actually realized how bad the rust was until I took it all out, and looked at it in pictures, oh well at least its gone.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
