1994 Left Turn Boogered - JeepForum.com
post #1 of 6 Old 06-22-2016, 07:11 PM Thread Starter
iowajeepers
Did the search, and replaced the relay, still acting the same.
What I got:
Left turn gives me a faint turn indicator, no flash.
Right turn works great.
Hazards work too.
I replaced the relay but still the same behavior.
At this point I'm assume the switch assembly is dodgy?
All help appreciated.
1994 YJ, 2004 WJ, 1976 C3, 2015 Slingshot, 2001 ZX6r
iowajeepers is offline
post #2 of 6 Old 06-22-2016, 10:52 PM
baritone_mike
By relay I am assuming you mean the flasher relay?
I would either replace both front and rear turn signal bulbs on the left side of the Jeep or swap them out for the ones on the right side of the Jeep. A bad bulb or contact can cause funny things to happen.
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #3 of 6 Old 06-23-2016, 06:59 AM Thread Starter
iowajeepers
But if it were a bulb, wouldn't that affect the hazards, which are working fine?
post #4 of 6 Old 06-23-2016, 11:04 AM Thread Starter
iowajeepers
Solved!
After doing multiple tests with the Hazards, 5 of 7 times the left front would NOT flash. Reseated the bulb and it started working as expected, including the Left Turn. I suspect it was corroded and would make contact "some of the time".
Good call and thanks for getting me to revisit the bulb situation and do more testing. Saved me a lot of frustration.
post #5 of 6 Old 06-23-2016, 01:09 PM
baritone_mike
No problem, I am not really sure why it does it but I had a similar thing happen not to long ago.
post #6 of 6 Old 06-23-2016, 04:07 PM
bruinjeeper
steel wool the contacts
Stop whining about the 'ride' - If your YJ ain't wrangling your soul free, then might I suggest you buy a stationwagon... at least you can fit all your bull**** in the back.
~YJOTM MAY '16~
bruinjeeper is offline
