1994 jeep wrangler yj won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1994 jeep wrangler yj won't start
AMP Research Powersteps - A Morris 4x4 Center PromotionCrawler Conceptz at JeepHut.comTime To Save On Yukon Lockers!
Unread 03-11-2014, 09:18 PM   #1
prewitt88
I have a 1994 Jeep Wrangler YJ that I took out yesterday through mud puddles and now it won't start unless I spray Ether in the air intake. Once the Jeep is started it stays running but when it shut off it doesn't start back up.
prewitt88 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2014, 09:47 PM   #2
Jeepsr4me
clean under the dist cap. Sounds like low voltage issue.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 03-12-2014, 01:37 PM   #3
prewitt88
It is clean under the distributor cap. I can get it started with starting fluid but when it does run it runs really rough even when I give it gas. It idles really low when I don't give it gas and it eventually dies.
Unread 03-12-2014, 02:39 PM   #4
Jeepsr4me
I assume you checked the air filter? They clogg up real easy with water soaking
