1994 Jeep Wrangler Laredo mirrors - JeepForum.com
post #1 of 9 Old 06-03-2013, 12:21 PM Thread Starter
gbuspa
Hi,
Would greatly appreciate forum help to identify outside mirrors model/manufacturer info. I'm trying to find these ones. See attached picture. These are for 1994 Jeep Wrangler Laredo build in Canada. Jeep dealler saying that these are not original (aftermarket).
Thank you.
gbuspa is offline
post #2 of 9 Old 06-03-2013, 06:20 PM
superj
they are aftermarket. why not get mirrors from a tj? thats what i did. they mount using the bolts on the door's hinge, those three in the triangle shaped metal part on the door. work great and look great
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 9 Old 06-03-2013, 06:22 PM
superj
excuse the sun fade. its always summer here and the sun burns everything after a while
superj is offline
post #4 of 9 Old 06-03-2013, 06:23 PM
superj
and i guess i misremember how they mount. i had to drill some holes for the mirror
superj is offline
post #5 of 9 Old 06-03-2013, 06:29 PM
idaholtby
Yes, if the rig did not already have factory mirrors, then you will need to drill and tap for them into the door hinge. Pretty much a mirror image of the bolt pattern used on the hinge to mount the door. TJ mirrors '03plus are awesome. They mate up perfectly to the standard YJ mounts and don't change adjustment every time the door is closed.
idaholtby is offline
post #6 of 9 Old 06-03-2013, 08:41 PM
Matt The Hammer
Man, they are ugly. I'd blame them on the metric system or Bryan Adams.
If you swap out those mirrors, you're going to have a big ugly spot where they were mounted. I'd pull them off and see what the door looks like under the mirror.
I know in the 90s, jeep was selling YJs with just a driver side mirror. Maybe someone went to Canadian Tire and bought some craptastic mirrors.
Sent from my rotary phone using JeepForum
2013 JKU
1995 YJ
Matt The Hammer is offline
post #7 of 9 Old 06-04-2013, 04:43 AM
superj
that is the spot where the factory mirror on my laredo was mounted on the passenger side. same on the driver's side. luckily, when i bought it, someone had already filled and smoothed the holes from the old style mirrors and had replaced the driver's with a tj one. i put the passenger one on
superj is offline
post #8 of 9 Old 06-04-2013, 03:44 PM Thread Starter
gbuspa
Thank you for all replies.
gbuspa is offline
post #9 of 9 Old 06-05-2013, 08:51 PM
Firefyter-Emt
If it was me, I would go with the newer TJ style mirror, and to fix your door,either paint it semi-gloss black in that indent (after filling the holes) or better yet, but the decal that fits that area. Jeep did have a smaller mirror that bolted onto that body in that area, but those were not the ones. Although... with Jeep, all things are possible!
Once I finish a little body work on my half doors and get them painted, I think I will pick up a set of the TJ style mirrors for the half doors and leave the old ones on my full doors.
Firefyter-Emt is offline
