11-05-2009, 02:33 PM
#91
Resident Audio Guru
I know this may sound like a silly question, but none of the symptoms would be caused by not filling the transmission with oil, could it? I didn't think to mention it because I drove the Jeep with the AX-5 and no oil in the transmission without an issue (Moving it around my driveway) after it blew a hole in my driveway. I didn't want to fill the transmission or transfer case up until I knew it was working correctly.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
11-05-2009, 02:37 PM
#92
You make me extremely nervous UltimatE.
11-05-2009, 02:46 PM
#93
Resident Audio Guru
Haha why is that?
-Matt
White '94 YJ Sport
11-05-2009, 03:03 PM
#94
Resident Audio Guru
Now that I think about it, increased internal friction from a lack of oil would actually work in my favor in preventing the input shaft from spinning.
-Matt
White '94 YJ Sport
11-05-2009, 04:57 PM
#95
Resident Audio Guru
Okay, so I dropped the transmission. (In a whopping 1.5 hours including eating and other stuff)
As we suspected, the clutch disc splines do indeed look to be very close to the fingers of the pressure plate. I am going back out now to get some measurements.
-Matt
White '94 YJ Sport
11-05-2009, 05:07 PM
#96
If you can post pictures, it definitely helps.
11-05-2009, 05:14 PM
#97
Resident Audio Guru
-Matt
White '94 YJ Sport
11-05-2009, 06:56 PM
#98
Resident Audio Guru
Alright I pulled the clutch off the flywheel and got some side to side pictures with the old clutch.
I placed 2 2x4's on my workbench to simulate the flywheel surface, and used the bench as a measuring point. So if you take the difference of these two measurements, it would be how much closer the new disc hub is to the pressure plate fingers.
With the caliper I measured 2.25" on the stock AX-5 clutch, and 2.675" on the '84 camaro clutch. So we're talking a good 0.425 LESS clearance for the throw out bearing to move.
-Matt
White '94 YJ Sport
11-05-2009, 07:33 PM
#99
Resident Audio Guru
And here's just a fun pic for you guys. I had an old clutch tool from my previous wrangler, an '88 with the BA 10/5. The input shaft matches -- 10 spline on a 1.125" diameter, however the pilot bearing was the smaller 0.59". What else would I do except use duct tape to make up the difference to 0.75" ? This thing has worked flawlessly twice now  Redneck engineering baby.
-Matt
White '94 YJ Sport
11-05-2009, 09:11 PM
#100
Resident Audio Guru
You guys think that 0.425" of lost clearance is my issue? I was very surprised to find out 2/3rds of my throw out bearing clearance was gone with the new clutch disc.
-Matt
White '94 YJ Sport
11-05-2009, 10:08 PM
#101
from here it gets rough
I think you have found what the problem is. You may be able to remove that extra length on the clutch spline hub with a cutoff wheel, then finish off with an angle grinder, then de-bur the splines and see how it goes. Remember, that pressure plate only pulls back a small amount, likely the extra length on the spline hub is the holdup that restricts travel.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock http://kamfamily.wordpress.com/2009/...waiian-limpet/
Originally Posted by Brian4.2
We will be going Metric every inch of the way.
Originally Posted by 40dog
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
11-06-2009, 12:22 PM
#102
Where did you get that disc? I have not seen that version I don't think. This is the one i have and how it fits on the flywheel, with much less of a center hub on the side that faces the pressure plate.
I have not tightened down the pressure plate on bottom pic, but just wanted to place it on there.
11-06-2009, 12:30 PM
#103
Resident Audio Guru
Its a disc I got from Autozone supposedly for a 1984 camaro with the 4cyl and 4-speed manual.
I was given a NAPA Part # RCF584 from czjeeper for a 9.125" diameter clutch disc with 10 splines on a 1.125" diameter. This clutch was used, as a reference, in early CJ5's with the 2.5L engine (1983 CJ5 with the 4cyl) That is the disc he used and works just fine.
What application / part number is your disc?
-Matt
White '94 YJ Sport
11-06-2009, 12:33 PM
#104
Wow, yea I do not like the look of it at all. I think your post/conversion will most likely be the example of which clutch disc to avoid.
11-06-2009, 12:44 PM
#105
Resident Audio Guru
I remember seeing a mention of the 84 camaro clutch in reading some of the writeup/posts... I guess that's out of the question now. Maybe it will work with the Dakota clutch setup because of the much larger pressure plate?
Either way I updated my previous post with more information and a quick question.
-Matt
White '94 YJ Sport
