1993YJ 5speed - JeepForum.com
post #1 of 9 Old 12-28-2009, 03:05 PM Thread Starter
1993BlackYJ
1993YJ 5speed
What trans do I have in my 1993 YJ I6 5 speed? I guess my sync's are going out in 1st-2nd. I cant get it in 2nd gear most of the time. I have 175,000 miles on her so I cant complain. While I doing it (Trans Shop will do the rebuild) I any going to replace the Clutch and Slave cylinder. Anything else I should look for? What should the rebuilt cost if I remove and reinstall the tranny.
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
My 93 Build Thread Over 700pics :
My 71 "Dorothy" Build Thread Lots of pics :
My 53 CJ-3B "Ray" Build:
Jesus Christ is my Lord and Savior
1993BlackYJ is offline
post #2 of 9 Old 12-28-2009, 03:10 PM
eshelton
You've got an AX15 and yes I'd definitely go ahead and replace the clutch since you're already in there. I wouldn't spend more than 300 or 400 on labor. There not really that hard to rebuild
eshelton is offline
post #3 of 9 Old 12-28-2009, 03:30 PM
Fhajad
Should look into making the slave cylinder external. There's some write ups around here.
Fhajad is offline
post #4 of 9 Old 12-28-2009, 03:45 PM Thread Starter
1993BlackYJ
Thanks for the input. I will look into it
1947 CJ-2A
1953 CJ-3B "Ray"
post #5 of 9 Old 12-28-2009, 03:50 PM Thread Starter
1993BlackYJ
is the AX15 better than the AX5?
1947 CJ-2A
1953 CJ-3B "Ray"
post #6 of 9 Old 12-28-2009, 03:55 PM
cubfanbudman
There are people running small Chevy's behind AX-15s. The AX-5 barely will hold the massive power of a 2.5.
1995 YJ -TBI350/NV3500/231J RC 2.5
1996 ZJ Laredo-4.0 NP242
1996-ZJ-Orvis Edition
Doug
cubfanbudman is offline
post #7 of 9 Old 12-28-2009, 04:00 PM
eshelton
Oh hell yeah! clubfan is right they barly can handle the 2.5L. Good thing about the AX5 though, for about $600 and few hours in your driveway you can have a another in
eshelton is offline
post #8 of 9 Old 12-28-2009, 06:49 PM Thread Starter
1993BlackYJ
How do I tell the difference between the AX5 and AX15 did it change with year models? I'm a noob. If I start looking for another in the future I will need to know what to look for it in.
1947 CJ-2A
1953 CJ-3B "Ray"
post #9 of 9 Old 12-28-2009, 10:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If you can do the removal yourself & the clutch install, I would recommend getting a FSM (Factory Service Manual) and rebuild it yourself. It's an easy rebuild, IMO.
Dead-on accurate!
You'll need a "front bearing retainer plate", a bellhousing complete with the clutch fork & fork pivot ball, a throwout bearing and a prebled master cylinder/hose/external slave cylinder kit. Your existing hydraulic hose won't work & the whole hydraulic kit is just over $120 usually.
MUCH!!!
No need to, the AX-5 was never used behind a 6 cylinder YJ engine.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
My 1st Jeep and Build 1993YJ 1993BlackYJ YJ Wrangler Technical Forum 1647 06-06-2013 03:43 PM
5speed to 6speed bluetj98 TJ Wrangler Technical Forum 10 01-20-2010 10:03 AM
91 auto in a 92 5speed? ghost183 YJ Wrangler Technical Forum 1 05-06-2008 06:14 PM
5speed to auto LOCKED UP YJ Wrangler Technical Forum 10 12-23-2006 05:41 PM
5speed ? bellhousing NOS/86 YJ Wrangler Technical Forum 5 01-28-2006 10:13 PM
