1993 YJ Sahara Paint Code Difference - JeepForum.com
post #1 of 3 Old 06-14-2011, 08:40 AM Thread Starter
weerwolv
Hi all,
Trying to figure something out before I buy some touch up paint as well as have my half doors painted.
Did the 1993 YJ Sahara come in only one color?
When I look up paint codes for that year (and mine is green in color) it gives out two codes..
PG5 Hunter Green metallic
or
AY96JG5 Hunter Green Metallic
To make things even better I have a lot of trouble seeing color difference. Are these the same paints under different codes or is there something different?
Thanks all in advance
weerwolv is offline
post #2 of 3 Old 06-14-2011, 08:53 AM
ziebartrob
Not sure what the AY96 part is, but JG5 was also used for PG5, which is Hunter Green Metallic. Same color as my heep. I have used the PG5 code in the past and it is dead on.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #3 of 3 Old 06-14-2011, 09:40 AM Thread Starter
weerwolv
Thanks so much. This helps a lot and what I'll probably do is grab a paint pen to start with just to make sure...
weerwolv is offline
1993 yj paint code needed Rocky_Cosmark Wrangler General Discussion 1 05-08-2012 10:38 PM
Soft Top recommendation for 1993 YJ Sahara weerwolv YJ Wrangler Technical Forum 11 02-27-2011 08:22 PM
Dark Green Paint/Color Spec 1993 Sahara? ClubberlangKO YJ Wrangler Technical Forum 7 05-20-2009 12:40 AM
Made an intake for my 1993 Sahara 4.0 - here's what I did Tobey YJ Wrangler Technical Forum 4 03-29-2009 06:17 PM
Sahara 1990 yj 4.2 Is the 4.2L reliable and whats difference with it Bein a Sahara bcameron1974 Wrangler General Discussion 8 12-23-2008 11:15 AM
