1993 yj 2.5 quit running wont start? - Page 6 - JeepForum.com
post #76 of 80 Old 05-30-2013, 01:54 PM Thread Starter
bedwards24676
Originally Posted by Que89YJ
remrmber the battery reset after you replace it.
Will do
bedwards24676 is offline
post #77 of 80 Old 05-30-2013, 04:28 PM Thread Starter
bedwards24676
absolutely. 52 and 22 will definitely cause it to run bad.
Ok Que help me out. New temp sensor. Disconnected battery still code 22. Connector looks good. Wiring looks good. Can I do a resistance test on the wiring. I know if anyone knows its you. If so tell me where to hook to on the other end. And if there's anything else that may be causing this let me know ill take a look at it.
post #78 of 80 Old 05-30-2013, 06:05 PM
Que89YJ
pm sent. call me
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #79 of 80 Old 06-01-2013, 08:36 PM Thread Starter
bedwards24676
Alright guys I'm happy to say after 1 problem turned into about 3 she is fixed. At least these 3 problems. Hell it's a YJ. Y'all know what I'm talking about. I have posted the fixes to the wont start (broke rotor button), code 52 high fuel pressure 71psi (blocked return inside tank), and the latest code 22 temp sensor. I recently put a thermostat in right before I pulled this code. Me knowing not much about these jeeps yet. I replaced the temp sensor. Still was there. Que guided me through putting the meter on the sensor and wires trouble shooting all looked good. Then he suggested like in many other threads here that I may have air in the thermostat housing right where the sensor is. Improper burping on my behalf. I took his advice installed a flushing "T" in the inlet hose. Started her up took the cap off the tee and here come the bubbles. Got all the air out. Disconnected the battery to clear the codes and went for a ride. That jeep drove better than I could have dreamed. It's been screwed up with problem here problem there since I bought it. Thanks to Que, Pete, and Max for all the help. This forum is full of fellow jeep addicts that want to lend a hand. All you have to do is sit back and learn.
post #80 of 80 Old 06-01-2013, 09:05 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Que and Max are the Seal Team 6 of the YJ Forums.
Sent by my pretentious iPhone.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
