1993 yj 2.5 quit running wont start? - JeepForum.com
post #1 of 80 Old 05-20-2013, 10:20 AM Thread Starter
bedwards24676
Hey guys. I haven't owned this yj but a few months but really have only put about 100 miles on it. Replace the transmission and overhaul on body new paint inside and out. Just put it back on the road last week. Last night I was coming home running about. 35 or 40mph. It sputtered about 3 times real hard, went dead and now wont start. Had to tow it home. What little I have drove it. It sputters every now and then but then goes back to running ok for a 20 year old jeep. Last night it sputtered as jerked hard though. Any tips on where to begin? Fuel, spark, how to test the ECM or PCM? Any ideas on where to begin would be helpful. Hoping its nothing catastrophic. Spend a lot of money on this thing already. But need it running ASAP. Open to any and all suggestions. Thanks guys.
bedwards24676 is offline
post #2 of 80 Old 05-20-2013, 12:04 PM
Que89YJ
Check your codes and post what you find:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Que89YJ is offline
post #3 of 80 Old 05-20-2013, 12:10 PM Thread Starter
bedwards24676
We were on the same page. Checked them at lunch. Here's what I got. 12,33,52,55. That's it.
post #4 of 80 Old 05-20-2013, 12:13 PM Thread Starter
bedwards24676
Where is the fuel pump located on this jeep, 93 2.5? What's the proper way to test if I'm getting fuel. At the rail? At the pump? Not really sure where the pump is located. But really haven't had time to look. It seems its spinning just a little more free than usual when I tried it last night. It would act like it was gonna start but just chug a few times and then back off?
post #5 of 80 Old 05-20-2013, 01:01 PM
Que89YJ
Spray some starter fluid into the throttlebody. If it cranks over then you have a fuel issue. You should hear the pump when you turn the key to start. 52 indicates that it is flooding. We will see what you have when you check for fuel and spark. A flooded start requires you to push the pedal to the floor to clear the fuel.
Que89YJ is offline
post #6 of 80 Old 05-20-2013, 01:19 PM Thread Starter
bedwards24676
Will do the starting fluid tonight after work. I am not hearing the pump when turning the key. Also last night I was holding the gas pedal to the floor when trying to start still nothing. The cel has not came on as well. Thanks for helping me try and get to the bottom of this. If its simple I need to avoid taking to a mechanic.
post #7 of 80 Old 05-20-2013, 01:25 PM Thread Starter
bedwards24676
Also I know that code 52 is saying its flooding I can't smell any gas at all???? So idk
post #8 of 80 Old 05-20-2013, 01:50 PM Thread Starter
bedwards24676
It has been backfiring a little so maybe running rich explains why.
post #9 of 80 Old 05-20-2013, 03:40 PM
idaholtby
Que's suggestion will yield results if you are running lean and need additional fuel (if I am following this correctly). Either flooded or lean, I would suggest checking your fuel pressure at the rail using the Schrader valve. You can rent a tester from most auto parts houses. Check the pressure with the pressure regulator in control and then removed from control. Do this by removing the vacuum line from the pressure regulator that resides at the front most section of the fuel rail. While this vacuum line is removed, also check to see if it is wet with fuel. If so, then the regulator diaphragm failed and is allowing fuel to be drawn into the intake manifold via the vacuum line unregulated. Report back the reading you have at idle with the fuel regulator vacuum line connected and then when it is removed. Also, when the engine is shut down, check and monitor the pressure to see if it bleeds down quickly. If it does, then it could be either a bad fuel regulator, and or a bad injector(s). If your pressure is abnormally high, then again, it could be a bad regulator or a pinched return line. We can address these possibilities once you report back your findings.
idaholtby is offline
post #10 of 80 Old 05-20-2013, 04:07 PM Thread Starter
bedwards24676
Ok sounds good ill stop by autozone and pick one up on the way home from work. Will report back what I find. Thanks
post #11 of 80 Old 05-20-2013, 05:53 PM Thread Starter
bedwards24676
Starting fluid nothing. There is fuel in the rail. No point of testing pressure because it won't start. At least I guess there is no point. Fuel pump is engaging when key is turned on. Engine spins over about 5 times then chugs spins the chug. Best way I can describe it to you guys. Could I have jumped time??? How would I know? Or worst case could my motor have kicked the bucket with no signs at all??? I'm stuck and on the fence whether to take it to the mechanic. Also after spinning over after spraying to small sprays of starting fluid a few seconds after trying it. The motor would hiss really loud. Could have been coming out if the throttle body and could've been from the starting fluid idk. Trying to find my spark tester to test spark.
post #12 of 80 Old 05-20-2013, 06:26 PM Thread Starter
bedwards24676
Good spark on #4, very faint spark on #3, nothing on #2, or # 1. Any suggestions? Thanks guys.
post #13 of 80 Old 05-20-2013, 06:33 PM
Que89YJ
getting close with no spark check your distributor cap and rotor
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #14 of 80 Old 05-20-2013, 06:34 PM
Que89YJ
it sounds like the pickup sensor in the distributor.
Fault codes:
No Start:
Que89YJ is offline
post #15 of 80 Old 05-20-2013, 06:56 PM Thread Starter
bedwards24676
Ok what would I need to do. Just drop in replacement? With no experience with ignition, timing, should I take her to the shop. I am mechanically inclined and can do plenty of things under the hood etc. but I'm not gonna tell someone I know what they are talking about when I don't. I'm very green to this sort of problem.
