1993 Wrangler Electrical - Starting Issues - JeepForum.com
post #1 of 9 Old 01-07-2012, 06:37 PM Thread Starter
Hemi2000
Hello, I'm a new member here. I just purchased a 1993 Jeep Wrangler from a friend. It's a 6 cyl automatic, sold new in California.
It is pretty much all original and has no obvious modifications to the engine or electrical system. My friend said it ran good before but one day he had a dead battery and tried to jump start it, he accidentally reversed the cable connections and things got hot in a hurry! He saw smoke and unhooked everything. It seems that a wire somewhere got hot and possibly melted but nothing appears damaged.
Now the car does not get any power from the (now charged) battery and will not attempt to start. I found a couple blown fuses and replaced them, no other obvious issues, same results.
Where do I start? Help!
Hemi2000 is offline
post #2 of 9 Old 01-07-2012, 08:23 PM
Mark05059
are you getting any cranking of the engine at all?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 9 Old 01-07-2012, 08:42 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
First off you sent voltage with amperage through the ground system of your entire electrical system. That is not good.
First thing; what exactly does "will not attempt to start mean" in plain third grade English?? Does it make any noise or does it turn the engine but not start??
You need to do is get the starter system to respond. Right now the starter is not making any noise what so ever.
You checked/replace fuses...which ones? Where were they? Did you check the start relay in the PDC under the hood? See if your horn works. If it does swap that relay with your starter relay. See what that does. In fact if you horn does work check every relay you have in the horn relay position.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 9 Old 01-08-2012, 04:57 PM Thread Starter
Hemi2000
Ok, I checked the battery connections again, both were loose. I cleaned up the posts and cables and secured everything properly (before I had a dead key, nothing when turned, no lights, horn, starter, etc. just dead).
Now I have interior lights (horn does not work) and the starter motor engages, turns the engine over and all sounds normal.....However the engine just cranks over and does not fire at all, I have fuel and suspect it lacks spark.
Hemi2000 is offline
post #5 of 9 Old 01-08-2012, 05:33 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Forget the horn for now... Humor me if you don't mind. Slide underneath the YJ and remove the electrical plug from the VSS sensor mounted on the transfer case. See if it starts then.
post #6 of 9 Old 01-08-2012, 07:46 PM Thread Starter
Hemi2000
Ok, tried that, no change. I do smell fuel now (flooded from cranking).
Hemi2000 is offline
post #7 of 9 Old 01-08-2012, 08:11 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Check out this thread:
http://www.jeepforum.com/forum/f12/n...oblem-1294163/
Rat had the same problem with his '95YJ. Your '93 is essentially the same except wire colors are probably different. You can see what you are possibly up against.
After it all the VSS was shorted internally collapsing the 8 volt supply to it and two other sensors.
post #8 of 9 Old 01-09-2012, 06:02 AM
Que89YJ
Do you see the check engine light on the cluster when you turn the key and does it go out after 3 seconds?
Que89YJ is offline
post #9 of 9 Old 01-15-2012, 04:46 PM Thread Starter
Hemi2000
Success! It was a bad coil, swapped it out and she started right up!
Hemi2000 is offline
1987 Wrangler Electrical Issues - no headlights, taillights, brakelights, dash lights rconn14 YJ Wrangler Technical Forum 13 05-26-2012 05:51 AM
'89 Wrangler starting issues. 89ClassicWrang YJ Wrangler Technical Forum 5 10-20-2009 08:02 AM
1993 4.0 Automatic Starting Issues Zavaslacker YJ Wrangler Technical Forum 1 02-07-2009 06:57 PM
1993 Jeep Yj Not Starting. 23bubba YJ Wrangler Technical Forum 7 02-07-2008 08:34 PM
1998 Wrangler Electrical Issues tfoul TJ Wrangler Technical Forum 10 10-10-2006 03:09 AM
