1993 wrangler with 4.88 gears? - JeepForum.com
post #1 of 9 Old 02-25-2009, 05:15 PM Thread Starter
Riddletown33
I'm looking to change my gears over to 4.88 instead of the 4.10 that are currently stock. There are a lot of different 4.88 gears when i do searches and I wanna verify which exact ones I need to purchase for my jeep. Thanks.
Riddletown33 is offline
post #2 of 9 Old 02-25-2009, 05:24 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Front = Dana 30 axle = 4.88 Reverse cut gears due to YJ high pinion axle arrangement
Rear = Dana 35 axle = 4.88 gears.
As long as they're the same ratio, brand name doesn't matter (Precision Gear, Superior Gear, etc.) front to rear, just look for the best deal on each set, IMO.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 9 Old 02-25-2009, 05:27 PM
shaggyjim
shaggyjim's Avatar
What axles are you running. If your running a 350 with yout stock axles then dont put the money into them. get something that will hold up and gear that.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #4 of 9 Old 02-25-2009, 05:30 PM
jeepdude1987
1987 YJ Wrangler
Upgrade the axles if your running that 350 like your profile says. If your not running the stock axles you will have to find out which you have under there.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels.
Caution!!! Under construction!!!!!! Caution!!!
Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD!
jeepdude1987 is offline
post #5 of 9 Old 02-25-2009, 05:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
WHOA NELLY!!!
Good call shaggy!
I should have looked at his profile, eh?
By the title & wording of his thread, I just assumed that he was stock!
Ford 8.8 gets my vote.
Mean Max is offline
post #6 of 9 Old 02-25-2009, 05:40 PM
shaggyjim
shaggyjim's Avatar
Originally Posted by Mean Max View Post
WHOA NELLY!!!
Good call shaggy!
Ya if that what he has got then I think the best thing would be a 44/8.8 combo. The 350 and 4.88 would snap shafts at a stop light.
Jim...
post #7 of 9 Old 02-25-2009, 06:55 PM Thread Starter
Riddletown33
sorry i need to update my profile. I do have a stock 2.5 l jeep now
post #8 of 9 Old 02-25-2009, 10:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
WHEW! That's a relief!
See post #2
Mean Max is offline
post #9 of 9 Old 02-25-2009, 10:47 PM
jgillespie
man i hate it when you take all the smarts away max! now i can't say anything useful that you didn't already say
'91 YJ 4.0 3/4'' Brandon Booms 31/10.50 BFG AT Herc'd CJ dash/tailgate CJ5 seats 4KCs cracked windshield
RED JEEP CLUB MEMBER 536
Originally posted by Crazyquadder:
a 6 foot puddle is approx half way up my doors
jgillespie is offline
jeep wrangler yj 1993 cyberbenny32 YJ Wrangler Technical Forum 7 08-05-2007 04:16 AM
1993 YJ hard to shift, grinding gears etc...help 1993jeep YJ Wrangler Technical Forum 16 12-02-2006 08:58 PM
1993 Jeep Wrangler gears? The Punisher YJ Wrangler Technical Forum 4 08-27-2006 10:26 PM
1993 Wrangler JDREDNECK YJ Wrangler Technical Forum 11 09-27-2005 08:05 PM
1993 Wrangler 2.5L thursten YJ Wrangler Technical Forum 4 08-07-2003 01:14 AM
