1993 wont start have 12 volts at coil - Page 2 - JeepForum.com
post #16 of 32 Old 08-17-2013, 08:27 AM Thread Starter
stacy1993joop
Paid $1,000
I'm patient, "But can we get this done today!!!!!" LOL
if you give me the wire diagrams and tell me what to check i think i can check every thing. i have the old alarm also.
my email address is my308cobra@msn.com. if you can send me the wire diagrams.
also when the jeep did start and ran it ran great went thru the gears along with the 4x4 stuff. and started and stopped probably 10-15 times.
the lights acted like they were tripping a resettable fuse like one of those little metal one i see on cars. and now when i turn on the flasher and head lights together the headlights dont flash like they did the other night.
youtube of headlight problem
and thank you guys again and this forum, i think i need to upgrade my account to a paid one because this help is priceless. ( humm i think i will use that saying in my sig line)
Just upgraded to --- Jeepforum.com: Premium Membership
Originally Posted by Que89YJ View Post
That is a big piece of info. You have power to the coil and the ECU. So the next step is to check cam/crank sensor power, ground, and continuity from the signal on each to the ECU connector. You sound like you can handle a meter so can you reading the wire diagrams? If you cant I will walk you through it. How much did you pay for the jeep? We can get you going. I have a decent handle on the electrical as long as you are patient.
stacy1993joop is offline
post #17 of 32 Old 08-17-2013, 08:36 AM Thread Starter
stacy1993joop
don't have a oscilloscope but i do have digital meter. and just bought a Analog display meter & injector noid light I'm ready to start testing something and will take direction & test and post the test results immediately. i have my lap top in garage with me.
Originally Posted by JWELK View Post
Another possibility is a "spread" pin on the ECU. Also check the "ground' wire from the ECU to the coil. Do you have access to an oscilloscope? If yes, you can check for pulses on the above "ground" wire. You might be able to see a "flicker" of meter movement if you have an analog VOM. The "ground" side should be at 12 volts with momentary pulses to ground.
You don't want to know how I discovered these things.
Let us know,
Regards,
Jim W
post #18 of 32 Old 08-17-2013, 12:11 PM Thread Starter
stacy1993joop
so checking on the headlight switch & found that was loose and might be causing it to blink i think anyway.
I found this mess.
post #19 of 32 Old 08-17-2013, 12:43 PM Thread Starter
stacy1993joop
so it looks like they cut the wires off the back of the fuse box and didn't leave any wire to reattach them to and one wire is missing. do i put a 20amp inline fuse or what? is that the correct location for the wires.
post #20 of 32 Old 08-17-2013, 05:06 PM
Que89YJ
You are on the right track. Funny thing though. I though that was pwer to the ecu. you said you had juice on 3 and 9 on the ecu.
Que89YJ is offline
post #21 of 32 Old 08-18-2013, 09:33 AM Thread Starter
stacy1993joop
I did / do have power to 3 & 9 but the PO have cut it off the fuse box and wired it strait thru with 2 spade connectors. i put an inline 20amp fuse.
post #22 of 32 Old 08-18-2013, 09:52 AM Thread Starter
stacy1993joop
update-
CPS
has 8 volts from pin 7 on PCM to center pin on female connector
have continuity from connector to pins 7 &24 on PCM
Speed sensor
has 8 volts from pin 7 on PCM to female connector
have continuity from connector to pins 47 on PCM
Coil
have continuity from connector to pins 19 on PCM
NO POWER to connector from relay!
So i popped open the relay and wedged a folded piece paper to close the relay and IT STARTED 5 or 6 times and even hook up the VSS to see if that was my original problem and it still started , i took a shower and went back out to start it and ZIP - NADA - nothing but still have 12 volts at the coil (w/ folded paper), still hear the fuel pump, unplugged the VSS and still no start checked the CPS and have a bad OHM reading so back to exchange that.
could the VSS let it start and then take out the CPS. hummm i think i will leave the VSS unplugged for a bit until i find out why the relay is not closing on its own.
AND A BIG THANK YOU GOES OUT TO Firefyter-Emt for posting this FULL wiring diagram in a post that i found
http://pdfcast.org/pdf/1995-jeep-wra...ctrical-system
post #23 of 32 Old 08-18-2013, 11:59 AM
Que89YJ
No way, the vss is separate. Glad to hear you got it started.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #24 of 32 Old 08-18-2013, 12:05 PM Thread Starter
stacy1993joop
changed out the CPS and still no start again.
post #25 of 32 Old 08-18-2013, 12:08 PM
Que89YJ
Disconnect the battery for a 10 count and try again
Fault codes:
No Start:
Que89YJ is offline
post #26 of 32 Old 08-18-2013, 11:09 PM
DirtKar
DirtKar's Avatar
I found this mess.
Is it the photo of is something happening with the integrity of the wire on the left with the darker blue spade connector? It appears to be smaller or damaged.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #27 of 32 Old 08-19-2013, 07:25 AM
JeepinAintCheap
im having this same problem mine happened after i took out the 2.5l to have it rebuilt put it back in and i get no spark replaced coil but cant see buying all new parts when it ran a short time ago cant find my crank censor i really starting to believe i dont have on lol if you guys have spare time could you post a picture of it on the jeep? thanks
JeepinAintCheap is offline
post #28 of 32 Old 08-19-2013, 10:14 AM
Que89YJ
Que89YJ is offline
post #29 of 32 Old 08-19-2013, 10:30 AM Thread Starter
stacy1993joop
If i unhook all other sensors except CPS, Cam sensor, and coil will that take the chance of one of the other sensors shorting power or whatever to the ground signal wire that goes to the computer like how the VSS does. I know that i need the other sensors to run properly but just looking to get it to start at this point.
post #30 of 32 Old 08-19-2013, 11:26 AM
Que89YJ
The jeep will be next to impossible to start. The temp sensor and map are critical. PM sent. Call me
Que89YJ is offline
