1993 Jeep YJ owners - JeepForum.com
post #1 of 20 Old 05-05-2003, 06:44 AM Thread Starter
JohnnyJeep
1993 Jeep YJ owners
Can I get any opinions good and bad on 1993 jeep yj..I would greatly appretiate it
Thank you Much
JohnnyJeep
JohnnyJeep is offline
post #2 of 20 Old 05-05-2003, 07:33 AM
BamaJeeper
BamaJeeper's Avatar
Get a 6cyl.
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 20 Old 05-05-2003, 08:43 AM Thread Starter
JohnnyJeep
Why the 6 just curious?
post #4 of 20 Old 05-05-2003, 08:43 AM
Pilky
Pilky's Avatar
Well iv been browsing these forums for a little while now....... im lookin for a Jeep also...... and all i can say from what i read is definitly get the 6 CYL.
Pilky is offline
post #5 of 20 Old 05-05-2003, 08:47 AM
Pilky
Pilky's Avatar
Like i said iv been looking for a Wrangler for quite some time now and did alot of research..... and learned alot more about them then what i orginal new (nothing) thanks to this forum...... i test drove a 97 4 CYL and i thought that it was under powered iv also heard that the 6 CYL is more reliable but that is based on word of mouth.
Pilky is offline
post #6 of 20 Old 05-05-2003, 09:22 AM
hondatech
I have a 94 4 cylinder, 5 speed. While it's no powerhouse, it moves along quite well. More than enough for any on road riding I would do here in hilly western PA. And while I'm not an experienced off roader, I would guess that it will be powerful enough for all but the most intense off roading.
hondatech is offline
post #7 of 20 Old 05-05-2003, 09:30 AM
tstrong12
tstrong12's Avatar
I have the 6 and wheel with a bunch of guys with the 4 and they do just fine. I met up with some guys this weekend running 36" tires and a four banger. He was crawling up every nook and cranny he could find. They did say however they were looking forward to dropping a bigger engine in so if you can afford it up front go with the six, because you'll more than likely want to upgrade later.
Regret is not an option...
1993 YJ 4.0 I6, 4" suspension lift 32's, Herculined
No Sway Bar, No Rear Track Bar
Upgrading as money allows
BLACK JEEP CLUB MEMBER #19
tstrong12 is offline
post #8 of 20 Old 05-05-2003, 09:31 AM
withamc
withamc's Avatar
While Jason Bunch competes with a 4 cyl TJ and does well, it's also had hundreds of pounds trimmed from stock configuration. If you want to go wheeling, you're gonna want a 6 cylinder. In the years I've been wheeling, most Wranglers I've seen on the trail have been 6 cylinders. Almost without exception, the owners of 4 cylinder Wranglers I've seen on the trail have expressed disappointment with the power. If you're gonna be cruising down fire roads, you'll probably be alright, but if you get into even moderate wheeling you won't be happy. And just wait till you've got to tug your buddy out of a rut.
Point Mugu 4 Wheel Drive Club
92 YJ - SOA, SRS, 44 front, 60 rear, Atlas II, 36's, Rustoleum White fenders, Herculiner interior
withamc is offline
post #9 of 20 Old 05-05-2003, 10:37 AM
Armory
I have a 93 YJ Sahara. Great jeep, I owned a 75 CJ before this and can safely say the jeep line keeps getting better. In-line 6 is the way to go. Very dependible and reliable. With a good air filter and some minor tweaks you'll be pushing 140hp no problem.
-USMC-
93’ YJ “Bouncing Betty”
ENGINE
Rebuilt 4.0L H.O. - Crane Camshaft - PaceSetter Air/FX Induction System - PaceSetter Headers - PaceSetter TFX Kat-Back System
SUSPENSION
SOA - RE 2.5 Springs - Rancho 9000's
OTHERS
35 x 12.5 x 15 Wrangler AT - Warn M8000 Winch - Tactical Console Light - Front & Rear Tow Hooks - UNIDEN 510XL CB - 3’ Wilson - Steel Horse Rock Gaurds
Armory is offline
post #10 of 20 Old 05-05-2003, 11:13 AM
hondatech
How many HP is the 4 cylinder? I've heard 120-ish, if all you get for the added expense of the 6 cylinder is 20 hp, then it seems like you'd be further ahead buying a cheap 4 cylinder and putting a more powerful motor in, like a V8, or a more powerful 6. 140 isn't bad, but it's not exaclty a powerhouse. With the way everyone reccomends it, I'm a little shocked it isn't more powerful.
post #11 of 20 Old 05-05-2003, 11:20 AM
clarky711
The 4.0 High Output in newer YJs is 190 horsepower. I think these started in 91 or 92 when they made the 6 cyl. fuel injected. Look for this sticker for the H.O.
Mike
01 Sport, 4.5" RE LA, 35" BFGs, 4.88 gears in Dana 44s, ARB up front, Eaton E-locker in back, Warn XD9000i, and a bunch of other goodies.....
Previously: 01 TJ on 32s, 94 YJ on 33s, 89 xj on 31s, 97 TJ on 31s, 79 CJ5 on 31s.
clarky711 is offline
post #12 of 20 Old 05-05-2003, 11:25 AM
yeep
it aint the HP thats important....
its the torque. 4.2IL6 produces its torque between 1800 and 2400 rpm. perfect for wheeling. 4.0IL6 is at somewhat higher rpm, but not much. like my buddies on the race team say (world challenge C-5R corvette) "torque is twist and twist is what turns tires"
Blue Jeep Club Member #4.2
Follow Me To Certain Death Jeep Club Member #34
90 YJ V-8, big *** tires, cut, streached, locked.
yeep is offline
post #13 of 20 Old 05-05-2003, 12:12 PM
namtrah
namtrah's Avatar
Don't forget the supercharger!
Yeah I think I am obsessed with Turbo or Super chargers. I know they are expensive, but they sure do add some power. I am looking to get a 1993-95 YJ with the 4.0L. The 4 cyl sounds great for mileage, but that is about it. The six gives you that extra oomph you may need to pull out Fords and Chevys, hee hee
04 WJ Laredo-4.0L-NP242-KN Fipk-Borla Exh w/Hi-Flo Cat-6" Lift
namtrah is offline
post #14 of 20 Old 05-05-2003, 12:22 PM
Armory
240 not 140, sorry for the typo (hadn't had my first cup of coffee yet).
The stock 4 puts out 123hp and the stock 6 will give you 180hp.
I looked into doing a V-8 mod but it's pretty pricey. The Dana 30 and 35c can't handle the load. So you have to switch them out and your tranny and driveshafts too.
You can drop a V-8 in a stock yj, but when you stomp on the gas things are going to break. Especially if you're running 33's.
Here's a good write up on the swap:
http://4wheeldrive.about.com/gi/dyna...e%2Fihscout%2F
The inline 6 with rear lockers is all you really need. Unless you have lots of money to blow.
-USMC-
ENGINE
SUSPENSION
OTHERS
Armory is offline
post #15 of 20 Old 05-05-2003, 07:42 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
If you get the 6-cyl and pop it (like I did twice) the newer Jeeps with the AX15 tranny can handle a Chevy 350 fairly well. Advance Adapter's can help you mate a 350ci to the AX15. The AX5 in the 4-banger doesn't really have enough jam to handle the output of power from a 350ci engine.
If you want the better gears, get a 4-banger, and plan for a V8 swap later down the road - but you will need a new tranny (and possible t-case as well).
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
1993 Jeep Wrangler YJ duvhuntr243 Wrangler General Discussion 3 07-08-2009 09:58 PM
Need help with new 1993 Jeep wranger 4cy!!!! rdclark1 YJ Wrangler Technical Forum 8 03-25-2009 06:35 PM
1993 Jeep Yj Not Starting. 23bubba YJ Wrangler Technical Forum 7 02-07-2008 08:34 PM
jeep wrangler yj 1993 cyberbenny32 YJ Wrangler Technical Forum 7 08-05-2007 04:16 AM
1993 jeep wrangler with 31" ajspellm YJ Wrangler Technical Forum 5 05-21-2005 04:52 PM
