1993 Jeep Yj Not Starting. - JeepForum.com
post #1 of 8 Old 02-07-2008, 06:36 PM Thread Starter
23bubba
I have a 1993 Jeep Wrangler 4.0 I6. I just recently installed A Performance Distributors Firepower Ignition Kit from Quadratec. It included a new Distributor, Rotor, Spark Plug wires, and ignition coil. I didnt start at first but i could pump the gas and get it started/running. I drove it for a day but it had a rough idle and it would sputter and kick while driving down the road at any speed. Now it wont start at all it will turn over but thats it. I just installed new spark plugs to see if it would help still no good. Any suggestions? Could it be Distributor timing, battery cables, ect....
23bubba is offline
post #2 of 8 Old 02-07-2008, 07:01 PM
pat8942
pat8942's Avatar
First off pumping the gas on a fuel injected engine does nothing so that was just a coincidence.
Maybe you didn't get the plug for the coil seated all the way and it's not getting voltage.
All other things being equal, the simplest solution is the best.
Ich liebe meinen Jeep!
pat8942 is offline
post #3 of 8 Old 02-07-2008, 07:04 PM
JimenyFKrickets
Junior Member
Sounds like the crank sensor...
JimenyFKrickets is offline
post #4 of 8 Old 02-07-2008, 07:27 PM
pat8942
pat8942's Avatar
Could be.
If something is gonna crap it always seems to happen after you replaced something else just to ruin your day.
pat8942 is offline
post #5 of 8 Old 02-07-2008, 08:01 PM
papa_panda
If your getting spark I would check the distributor timing- I replaced the dist. on an old chevy I had once and it behaved very similar to what yours is doing- it was only off by one one gear tooth, but that's enough... as far as the engine's concerned you may as well have a blown timing chain.... bring the timing mark on the harmonic balancer to 0 deg and remove the dist. cap- the rotor should be pointing either directly at or directly away from the #1 terminal...hope this helps...
'92 White YJ w/Grey soft top, 2.5L from '97 TJ, original 5-Speed, Silver Grizzly Alloy rims from 2001 TJ with Goodyear Wrangler GS-A 225/75R15
Marine Corps Jeep Club Member #7
White Jeep Club Member #350
papa_panda is offline
post #6 of 8 Old 02-07-2008, 08:07 PM
pat8942
pat8942's Avatar
I could be mistaken but I think he just changed the cap because I looked up the kit he got.
pat8942 is offline
post #7 of 8 Old 02-07-2008, 08:15 PM
89jeep2
1989 XJ Cherokee
If at all possible, put out stuff back on. If it runs like it should, then you know for sure that the new parts are defective or not installed correctly. In addition, this procedure(if it still doesn't run with old stuff back on) will conclude that it is not the new parts.
Have you checked to see if you hooked up the spark plug wires in the correct order? Spark plug order is on intake manifold.
89jeep2 is offline
post #8 of 8 Old 02-07-2008, 09:34 PM Thread Starter
23bubba
i got it running my ignition coil plug was a lil loose and changing the spark plugs helped quite a bit too. So far its been running fairly good. Time will tell. Thx!
23bubba is offline
1993 Jeep Wrangler YJ duvhuntr243 Wrangler General Discussion 3 07-08-2009 10:58 PM
1993 4.0 Automatic Starting Issues Zavaslacker YJ Wrangler Technical Forum 1 02-07-2009 07:57 PM
1993 2.5 4 Cyl Starting Problem OldSchoolRodz YJ Wrangler Technical Forum 10 10-04-2007 02:14 PM
jeep wrangler yj 1993 cyberbenny32 YJ Wrangler Technical Forum 7 08-05-2007 05:16 AM
1993 Jeep YJ owners JohnnyJeep YJ Wrangler Technical Forum 19 05-07-2003 08:20 AM
