1993 clutch master cylinder help - JeepForum.com
post #1 of 3 Old 05-16-2010, 08:02 PM Thread Starter
khekele
I started to remove the clutch master cylinder out of my jeep and got it completely unbolted except can't get the hydraulic line disconnected from the master cylinder. Since i have a 1993 i should be able to disconnect the line at the master cylinder, but it just has a square head with the line running out the side of the bolt that is loose (can move like it is unscrewing a little), but can't get it unscrewed out. How do i get it removed?
This is my first time really working in the jeep engine compartment so i am trying to figure out a lot of this as I go.
khekele is offline
post #2 of 3 Old 05-16-2010, 08:12 PM
Burnerman
Burnerman's Avatar
If you look closely you'll see a small roll pin that goes sideways thru the body of the MC. It goes thru a slot in the metal fitting attached to the line. I use a small punch and tap it out a little then grab it with cutting pliers and pull it out the rest of the way. Then the metal fitting will pull straight out.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #3 of 3 Old 05-16-2010, 08:16 PM Thread Starter
khekele
i figured that had something to do with it and it was that easy. Thanks
khekele is offline
94 Clutch Master Cylinder Help soonermatt YJ Wrangler Technical Forum 4 05-16-2009 11:07 AM
Clutch Master Cylinder Kit? creeper521 YJ Wrangler Technical Forum 3 12-01-2005 04:52 PM
need help fast! clutch/master cylinder no clutch! miguelitojeep97 TJ Wrangler Technical Forum 3 12-01-2005 01:53 AM
Clutch, Master Cylinder, and Slave Cylinder replaced and problem not solved.... loudog3114 TJ Wrangler Technical Forum 7 08-31-2005 08:37 AM
Clutch Master Cylinder? dsj2086 YJ Wrangler Technical Forum 3 07-28-2005 11:11 PM
