1993 2.5L Jeep Wrangler Build/5.2L Swap - Page 13 - JeepForum.com
post #181 of 207 Old 09-02-2013, 01:14 AM Thread Starter
Rynfw100
I changed the Crankshaft position sensor to the MOPAR one this weekend, along with a new fuel filter. Having the same problem with the engine dying without the throttle being fluctuated. It won't stay on unless you open and close the throttle constantly. Also a month ago I properly got the alternator hooked up, checked the Map sensor, etc.
I'm down to two things, either the PCM is bad or the grounds aren't hooked up properly. I'm going to look at the diagrams and see if everything is still copacetic. If not, I'll be in the market for a new computer. BTW, if anyone has a PCM for a 5.2L 318 for a 94-95 Dakota/Ram with a Manual Transmission that they know works, please let me know.
Happy Labor Day
My 5.2L V8 swap and Jeep build:
http://www.jeepforum.com/forum/f12/1993-2-5l-jeep-wrangler-build-5-2l-swap-1210512
Rynfw100 is offline
post #182 of 207 Old 09-02-2013, 05:02 AM
Que89YJ
Did you do the distributor?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #183 of 207 Old 09-02-2013, 08:00 AM
Que89YJ
Sorry, I mean to ask if you did the entire distributor or just the pickup? Idle is basically the IAC, temp sensor and the fuel to the rails. Did you ever check to see if the IAC is working? Is the fuel pressure finally holding?
Que89YJ is offline
post #184 of 207 Old 09-02-2013, 10:04 AM Thread Starter
Rynfw100
Fuel pressure seems to be fine. I have not messed with the distributor or the cam shaft sensor, as you have to buy the entire assembly and I'm getting good spark, but its something to think about.
The IAC was cleaned, and I've done some research on how to test the IAC, but nothing that I found really said if it was testable.
Rynfw100 is offline
post #185 of 207 Old 09-02-2013, 10:13 AM
Que89YJ
YouTube has video. Test the iac movement and pindl switch. I can link you tomorrow. Hit me up with a pm if I forget.
Fault codes:
No Start:
Que89YJ is offline
post #186 of 207 Old 09-02-2013, 10:55 AM Thread Starter
Rynfw100
YouTube has video. Text the iac movement and pindl switch. I can link you tomorrow. Hit me up with a pm if I forget.
Please do, I'm already scouring Youtube for the video, there are some videos that show movement, but they have a special pre-made box of some sort that sends pulses to the IAC which retracts and pushes out the spindle. Is there some sort of test that you could set up at home with a basic set of electronic tools? Those are my favorite
I'm thinking of just removing the IAC, while still plugged into the harness, turning the key into the ON position, check for movement, if nothing, crank, if nothing I should assume it's bad?
Rynfw100 is offline
post #187 of 207 Old 09-03-2013, 08:59 AM
bmgadg
A bad PCM would cause weird things to happen. I chose to buy one online that had been tested in a vehicle and had a warranty instead of looking in junk yards. It's the brain of your build, and worth the extra coin to ensure it's working properly.
bmgadg is offline
post #188 of 207 Old 09-03-2013, 09:25 AM Thread Starter
Rynfw100
Do you have a link to their site?
Rynfw100 is offline
post #189 of 207 Old 09-03-2013, 10:21 AM
bmgadg
Man it's been a while now, I don't remember exactly who it was. Seems like it may have been someone on eBay that also has an online store. I can dig around a little and probably find you something, but I'd start with doing some google searches for remanufactured PCMs if I were you. That's assuming you've narrowed it down to being a bad PCM, but after reading through your thread it's seeming more and more likely in my opinion.
bmgadg is offline
post #190 of 207 Old 09-30-2013, 06:49 PM Thread Starter
Rynfw100
Before I give the most recent update, I must give credit where it is due. After speaking on the phone with Que for about 30 minutes, and getting an understanding on certain procedures, I removed the IAC valve and let the son of a gun crank.
After cranking like it had for about 5 seconds, the hole where the IAC valve used to be started sucking air, and the engine started to rev. I blocked the hole with an old credit card, and it began to idle.
So Mr. Que, thank you sir.
Next up, finding where the fault lays for the IAC Valve, so I'm going to test my wiring to make sure the IAC is getting signal. Is there a way I should go about this? I don't see anything in the FSM or on the forums just yet. Depending on the result of this, I will take my next course of action.
But now I no longer have an excuse, so I will save up some money, get the little stuff done here in the next couple of weeks (ie. Fluids, Hoses, Drive Shafts, Master/Slave cylinder, etc.) and try and get this beast road worthy. Cause my daily driver (99 Ford E-350 w/ Extended Top) sucks up alot of gas.
Rynfw100 is offline
post #191 of 207 Old 09-30-2013, 08:50 PM
skyj
Good for you bud! its good to see all these 5.2 swaps on here lately. Sub'd
build thread:
skyj is offline
post #192 of 207 Old 10-01-2013, 01:42 PM
Que89YJ
Check to see if the iac moves with either the diagnostic tool. Glad to hear its running.
Fault codes:
No Start:
Que89YJ is offline
post #193 of 207 Old 10-01-2013, 02:57 PM Thread Starter
Rynfw100
Where do I get a diagnostic tool? Any way to check my wiring?
Rynfw100 is offline
post #194 of 207 Old 10-01-2013, 04:29 PM
Que89YJ
Use a meter and connect one side to each end of the 4 wires from the iac to the ECU and measure the resistance. Give me a call.
Fault codes:
No Start:
Que89YJ is offline
post #195 of 207 Old 10-03-2013, 08:12 PM Thread Starter
Rynfw100
I did just this, except I looked for continuity and got it, so the wires are sound. Because I could not find anyone doing this on the YJ forum or the ZJ forum, I'm going to post what I did here.
To test the IAC wires, you plug your multimeter into the IAC connector, and then into the same wire on the ECU/PCM Side. Here's what I came up with:
PCM PLUG
39 - K39 186Y/RD - IDLE AIR CONTROL MOTOR DRIVER
40 - K40 18BR/WT - IDLE AIR CONTROL MOTOR DRIVER
59 - K59 18VT/BK - IDLE AIR CONTROL MOTOR DRIVER
60 - K60 18YL/BK - IDLE AIR CONTROL MOTOR DRIVER
IAC PLUG
1 - K39 18GY/RD - IDLE AIR CONTROL MOTOR DRIVER
2 - K60 18YL/BK - IDLE AIR CONTROL MOTOR DRIVER
3 - K40 18BR/WT - IDLE AIR CONTROL MOTOR DRIVER
4 - K59 18VT/BK - IDLE AIR CONTROL MOTOR DRIVER
IAC -> PCM
1 Gray/Red -> 39
2 Yellow/Black-> 60
3 Brown/White-> 40
4 VT/Black-> 59
So for Position 1, the Gray Wire with a Red stripe, I plugged that into the PCM plug at 39, and so forth. Now if I need to measure Resistance, I'll have to do that another night.
Anyways, I got the coolant system finished, minus proper sized hose clamps. I'll get the steering finished tomorrow as well, just need to get tiny hose clamps for the power steering return line, and a longer return line...
If I don't have anything else to check on the IAC wiring before I go and get a new IAC motor, Looking at you Que89YJ , I'll get a new motor.
After all that the only things I need are new fluids for the Tranny/T-Case, Driveshafts, and exhaust... I see the light at the end of the Tunnel
Rynfw100 is offline
need help with my 1993 jeep wrangler, can anyone help? Fouse YJ Wrangler Technical Forum 9 09-27-2016 12:18 AM
Considering a 1993 Jeep Wrangler S GJeepFan YJ Wrangler Technical Forum 11 07-27-2011 03:42 AM
1993 Jeep Wrangler YJ duvhuntr243 Wrangler General Discussion 3 07-08-2009 09:58 PM
jeep wrangler yj 1993 cyberbenny32 YJ Wrangler Technical Forum 7 08-05-2007 04:16 AM
My new 1993 Jeep Wrangler Sport YJ 4x4 elapheguttata YJ Wrangler Technical Forum 18 03-14-2004 11:23 AM
