1992 YJ Won't Shift Into Gear - Page 2 - JeepForum.com
post #16 of 25 Old 06-09-2012, 11:46 AM
trabag18
yeah no problem ill check back after my graduation ceremony today see if you have any more questions
trabag18 is offline
post #17 of 25 Old 06-10-2012, 09:07 AM Thread Starter
fyallm
Well I started to pour in the fluid and it took maybe 1oz of fluid so I guess it wasn't low. I put the cap back on. pushed the clutch in 3-4 times and tried it again and still nothing. I took the cap off to see where the level was and it was where I had filled it :/
fyallm is offline
post #18 of 25 Old 06-10-2012, 09:12 AM
trabag18
well was the clutch working yet? if it was your a lucky one but keep pushing that clutch itll either start leaking or youll get lucky and the jeep fairies have paid you a visit
trabag18 is offline
post #19 of 25 Old 06-10-2012, 10:05 AM Thread Starter
fyallm
Nope, the clutch still wasn't working, turned it on and still nothing.
Is there where I should be looking for the other leak?
fyallm is offline
post #20 of 25 Old 06-10-2012, 02:08 PM
trabag18
yeah should be coming out right there im confused as to why its not leaking any where. has the level gone down in the MC?
trabag18 is offline
post #21 of 25 Old 06-10-2012, 02:36 PM Thread Starter
fyallm
I think it might be leaking there, maybe a super slow leak
fyallm is offline
post #22 of 25 Old 06-10-2012, 02:41 PM Thread Starter
fyallm
Well the jeep fairy has arrived because I just went out again and pumped the clutch after turning it on and now it will go in and out of gear.
I opened the hood and I can't tell if I spilled some of the brake fluid on the MC or not, but it had a little on it, so that could be where my leak is as well. I will try and keep an eye on both the MC and bell housing to see which is leaking (my luck its both)..
I did have another question though. so under the cap there is a rubber almost like nipple looking thing. It isn't attached to the cap but sits between the cap and hole almost like a washer but it is kinda squished, could that be where the leak is happening?
fyallm is offline
post #23 of 25 Old 06-11-2012, 05:53 PM
trabag18
Yeah ik they would have a leak somewhere but it's best to replace them at the same time any ways. The rubber thing goes in to the cape wide part first mess around with it you'll get it. So now you should decide will you do the clutch you self or have a shop do it. I'm 17 and iv done it it's not that hard
trabag18 is offline
post #24 of 25 Old 06-11-2012, 05:54 PM
trabag18
And yeah it might cause the leak if it's coming from under the cap
trabag18 is offline
post #25 of 25 Old 06-12-2012, 11:03 AM Thread Starter
fyallm
Is that rubber piece suppose to be connected to the cap? Also your saying replace what part?
fyallm is offline
clutch , gear , shifting issues
1992 5th gear problem smellslikegas YJ Wrangler Technical Forum 5 04-22-2012 06:28 PM
1992 YJ First Gear problem karenmascaro YJ Wrangler Technical Forum 2 10-11-2011 03:16 PM
Can't Shift Out of 1st Gear Bridges31 YJ Wrangler Technical Forum 6 11-13-2010 08:38 AM
Stock gear ratio for 1992 jeep wrangler mediocreme YJ Wrangler Technical Forum 4 06-30-2009 11:55 AM
My brothers 1992 jeep won't rev past 2800...shift light comes on and car stutters Jerzeyrex YJ Wrangler Technical Forum 13 02-10-2009 02:08 PM
