1992 YJ Won't Shift Into Gear - JeepForum.com
post #1 of 25 Old 06-09-2012, 07:05 AM Thread Starter
fyallm
Went out to my jeep started her up, and went to put it in reverse and nothing, it wouldn't go. The clutch feels really loose and its pretty easy to push it all the way to the floor without very much effort. When I shut the jeep off it goes into gears without pushing in the clutch (which should be normal) but I don't even know where to begin, Clutch's are not my specialty so any help will be appreciated!
fyallm is offline
post #2 of 25 Old 06-09-2012, 07:24 AM
Jeepsr4me
Have you checked the clutch MC fluid level?
Jeepsr4me is offline
post #3 of 25 Old 06-09-2012, 07:39 AM Thread Starter
fyallm
I have not, where would I be able to check that?
fyallm is offline
post #4 of 25 Old 06-09-2012, 07:43 AM
Jeepsr4me
post #5 of 25 Old 06-09-2012, 08:37 AM Thread Starter
fyallm
Is this it?
I would imagine since I don't really see any fluid it means its empty?
fyallm is offline
post #6 of 25 Old 06-09-2012, 08:51 AM
Jeepsr4me
Yeap. You low... and got a leak.. Fill it up and see how long it takes for it to all go bye bye... I milked one along for months.. But you dont want to know what I put in it..... Just get a bunch of brake fluid.. Good thing is you about to get new clutch....
post #7 of 25 Old 06-09-2012, 08:57 AM Thread Starter
fyallm
What kind should I put in it? I think the cap just says DOT 3. Something like this will work: http://www.autozone.com/autozone/acc...ier=33408_0_0_ ?
So that's the short term solution, how do I fix it long term?
fyallm is offline
post #8 of 25 Old 06-09-2012, 09:01 AM
jeepinmichguy_
I just got a prebled master/slave from rock auto for $111 shipped (although mine is an external slave to it took me about 30 min to do). If you don't have any fluid by the master it is more than likely the slave went out. If that is the case you will have to pull the tranny to swap it.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Originally Posted by JeepForum123 View Post
you all have nice rigs, stop being f****** a**holes.
jeepinmichguy_ is offline
post #9 of 25 Old 06-09-2012, 11:19 AM
trabag18
hey this same thing happend to me what you want to do is fill the master cylinder with brake fluid then check and push in the pedal a few times and see if fluid is leacking from the the bell housing if it is you need a new slave cylinder and since its a 92 its internal so you need to pull the tranny to replace it. and if it leaks inside the fire wall on your feet you need a new master cylinder
trabag18 is offline
post #10 of 25 Old 06-09-2012, 11:25 AM Thread Starter
fyallm
Alright, just bought some prestone dot3 brake fluid about 24oz so we will see if that is enough. I didn't notice any thing leaking inside near my feet before but i will check after I fill it up. Where is the bell housing? Of course I can't find my haynes manual right now :/
fyallm is offline
post #11 of 25 Old 06-09-2012, 11:30 AM
trabag18
where the transmission bolts to the back of the engine the oil pan ends right before it youll figure it out and just watch for clear fluid dripping out
trabag18 is offline
post #12 of 25 Old 06-09-2012, 11:34 AM Thread Starter
fyallm
Ahh ok, i think I know where you are talking about and if my memory serves me right I think I might have seen something dripping there before and i couldn't figure it out, but hopefully not. Also I just found my manual and i want to make double sure I'm looking at the clutch MC because the manual says it should be translucent but mine is black.
fyallm is offline
post #13 of 25 Old 06-09-2012, 11:41 AM
trabag18
it can turn black over 20 years mine dide just from the rubber and plastic breaking down if it is black just get some on your fingers to to check if its oil like consitencey or brake fluid like
trabag18 is offline
post #14 of 25 Old 06-09-2012, 11:44 AM Thread Starter
fyallm
Alright will do, thanks again for the help. Going to do this when I get back home tonight
fyallm is offline
post #15 of 25 Old 06-09-2012, 11:45 AM
Jeepsr4me
yes its the black one.
clutch , gear , shifting issues
1992 5th gear problem smellslikegas YJ Wrangler Technical Forum 5 04-22-2012 06:28 PM
1992 YJ First Gear problem karenmascaro YJ Wrangler Technical Forum 2 10-11-2011 03:16 PM
Can't Shift Out of 1st Gear Bridges31 YJ Wrangler Technical Forum 6 11-13-2010 08:38 AM
Stock gear ratio for 1992 jeep wrangler mediocreme YJ Wrangler Technical Forum 4 06-30-2009 11:55 AM
My brothers 1992 jeep won't rev past 2800...shift light comes on and car stutters Jerzeyrex YJ Wrangler Technical Forum 13 02-10-2009 02:08 PM
