1992 YJ Help - JeepForum.com
post #1 of 14 Old 11-05-2013, 07:58 AM Thread Starter
scoot_mcgrute
1992 YJ Help
Hey guys, my buddy Paul talks about this place quite a bit, thought I would sign up and see if I can get some help with my Jeep.
I got in a hurry the other day when hooking up some jumper cables and hooked them up backwards. When I realized it, I hooked everything up proper and it cranked but wouldn't fire. I also noticed some smoke coming from the computer area of the firewall. I unhooked the battery, let it sit overnight, and threw another battery in it to see if it would start. It still didn't start (just cranked) and more smoke came from the ECU.
I blew both of the 50A fuses for the alternator but that seems like all of the fuses for now. It's a 2.5 and my computer has 56027 380 on the side, a buddy has one that has 56027 364 on it from a 93. Will these be compatible?
I'm usually very anal about the jumper cable process process but I let my guard down and it's biting me in the butt.
Scott
scoot_mcgrute is offline
post #2 of 14 Old 11-05-2013, 08:44 AM
Que89YJ
Any 91-95 2.5L YJ computer will fit. The XJ 2.5L will work too but they had Nuetral saftey switches and had security in some of them too. There is a good thread to check the power going into the ecu on pins 3 and 9 and the 30 amp fuse in the PDC for the ignition run start. If you have power to those pins and you have a no start then ecu replacement time. Call my friend Chris, and tell him Que sent you. He will give you a good deal. If you dont have power follow the instructions and they will get you pointed in the right direction:
Troubleshooting thread:
http://www.jeepforum.com/forum/f12/9...lained-490788/
Parts:
http://www.cfoffroad.com/
Que89YJ is offline
post #3 of 14 Old 11-05-2013, 12:30 PM Thread Starter
scoot_mcgrute
Perfect, once I figure out how to keep it from letting the rest of the smoke out, I will see what happens.
I'm guessing that when the battery was hooked up backwards, a couple of wires in the harness got hot and are arcing out.
post #4 of 14 Old 11-05-2013, 06:10 PM
The_Goob
Hell on Wheels
The_Goob's Avatar
too bad you arent here, theres a 95 2.5 at the upull with the comp still in it for $30.
And welcome to jeepforum!
YJoTM ~April '14 ~June '15 ~April '17
The_Goob is offline
post #5 of 14 Old 11-06-2013, 06:14 AM
YJames90
YJames90's Avatar
Good turning radius or is something broken?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #6 of 14 Old 11-06-2013, 07:11 AM
superj
might be worth while asking for someone with a yj in the junkyard near by to pull the ecu for you and mail it to you, you pay, of course.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #7 of 14 Old 11-07-2013, 03:46 PM Thread Starter
scoot_mcgrute
Is that a lot of turning? It's got the MORE steering on it but everything else should be standard. I've only had it a few months so I'm still learning about this Jeep thing .
I've got a line on that 93 ECU for cheap, just still going through the harness to make sure it's all good before I pick it up from him.
post #8 of 14 Old 11-07-2013, 07:37 PM Thread Starter
scoot_mcgrute
Looks like I may have found the issue. I looked at all the wires in the harness and everything checked out ok. I plugged the computer back in and after a minute or 2, the ECU started smoking again. I unplugged it from the battery and then unplugged the harness from the ECU.
The pin for the Auto Shutdown Relay came with the plug. I'll slap a new relay in it and button it all back up once I get the new ECU. Here's to hoping it fixes it!
post #9 of 14 Old 11-08-2013, 04:09 AM
Que89YJ
There isn't a short on the ecu? Keep us updated.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 14 Old 11-10-2013, 08:49 PM Thread Starter
scoot_mcgrute
Not sure exactly. Since they decided to pot the ECU, I can't tell what is going on. I've got the harness all back together and in place, tomorrow I will get that new computer sent down.
I did notice tonight that the IOD fuse was blown. I have stripped the alarm wiring out of it and the dual battery kit wiring (single battery now) and found the fuse blown after that.
What does the IOD fuse do?
post #11 of 14 Old 11-10-2013, 09:46 PM
Que89YJ
Supplies all the nonessential powee to devices. They pull out for shipping to stop battery drain.
Fault codes:
No Start:
Que89YJ is offline
post #12 of 14 Old 11-12-2013, 10:18 PM Thread Starter
scoot_mcgrute
Sorry, been busy with getting ready to transition into a new job in a couple weeks.
Does the auto shutdown circuit cut the fuel?
I haven't gotten the new computer just yet but tried starting it tonight just to see if it would and I can't hear the fuel pump kick on right now. Didn't start of course...
post #13 of 14 Old 11-13-2013, 07:12 AM
Que89YJ
The fuel pump is controlled by the computer and you let the smoke out of it!. If you want to know if the fuel pump is good jumper pin 30 to 87 on the fuel pump relay.
Que89YJ is offline
post #14 of 14 Old 11-13-2013, 07:22 PM Thread Starter
scoot_mcgrute
Thanks for all your help! New to this type of system so I appreciate it.
I got my new to me ecu tonight and it fired right up and ran like a champ! Alternator seems to still be charging too. I think I did a lot of extra work but I now know more about the Jeep and diagnosing it's little issues that I may encounter.
Now it's time to button it all back up and take it for a spin
