1992 yj bad belt squeal - Page 2 - JeepForum.com
post #16 of 27 Old 07-10-2013, 11:29 AM
superj
tops been off since i bought a softopper but the 100-112 degree temps with 90% humidity are just to much, ha ha ha.
i actually think its the black paint that makes it so hot
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #17 of 27 Old 07-10-2013, 03:34 PM Thread Starter
Jacoblytleyj
I was able to put a breaker bar on my harmonic balancer and with out it in gear it tightened about a quarter turn and there suposed to be at 90 lbs I believe. I'm change my alt and get a harmonic balancer installer tool and torque it down. Just a quarter turn made it squeal less on start up. I don't have a/c. My engine is just a 1992 4.0 ho with p/s. my belt is 71 inches long. It pissed me off when I put a gator back belt on it and it got WORSE. I was surprised cuz of all the good things iv herd about them. That's what makes me think my harmonic balancer moved outward cuz when I put the belt on my power steering and altornator were skreeching not even a squeal anymore
Jacoblytleyj is offline
post #18 of 27 Old 07-10-2013, 03:44 PM
pasinbuy
Originally Posted by 92BlackandBlue View Post
AC?!?! If it's hot enough for ac it's hot enough to take the top off! JK!
Spoken like a person that does not live in a warm state!
I could remove my heater and never miss it. Not my AC!
pasinbuy is offline
post #19 of 27 Old 07-10-2013, 07:17 PM
92BlackandBlue
It gets pretty warm here, and I moved here from Palm Springs. It gets warm there too!
92BlackandBlue is offline
post #20 of 27 Old 07-10-2013, 07:51 PM
superj
Northerners.
Ha ha ha, just playing. It gets hot up north too. We would go to Virginia and the Carolinas in the summers and it was hhhooootttt.
superj is offline
post #21 of 27 Old 07-11-2013, 06:38 AM
HaskiE
HaskiE's Avatar
you fixed it! awesome! Congrats!
#theneverendingaxe
HaskiE is offline
post #22 of 27 Old 07-11-2013, 10:54 AM Thread Starter
Jacoblytleyj
No haven't fixed it yet
post #23 of 27 Old 07-11-2013, 10:58 AM
HaskiE
HaskiE's Avatar
hmm reading... still working on that one
#theneverendingaxe
HaskiE is offline
post #24 of 27 Old 07-11-2013, 06:35 PM
jeffy
jeffy's Avatar
So how'd you put the belt back on? A 71" is the standard belt for a YJ W/O AC but with PS. The proper way to install and remove the belt is to loosen the PS pump. IIRC it's 3 13mm bolts. Might be 15mm. Two on the backside and one on the front up high. Once those are loosened there is a lock bolt at the bottom of the PS pump. loosen that. Under the PS hoses pointing at the driver side fender is a long bolt. Loosen that and you will be able to move the PS outward, tightening the belt. If you tighten it it will draw in the PS pump allowing you to remove the belt.
I'm betting the belt is too loose and your alternator when under load is slipping enough not to be able to recharge the battery. If your pulley's aren't aligned then the belt would come off.
*** www.4BangerJP.com ***
jeffy is offline
post #25 of 27 Old 07-12-2013, 07:04 AM
wendell
1987 YJ Wrangler
Jeeps have belt squeal, that's how they roll.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #26 of 27 Old 07-12-2013, 10:00 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
X2.
It comes an it goes. Depending upon how dirty my engine is.
Posted via my pretentious iPhone.
91 YJ "Alice" 4.0L, AX-15, NP 231 w/HnT Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #27 of 27 Old 07-12-2013, 11:25 PM Thread Starter
Jacoblytleyj
My alt charges just fine. It's just the harmonic balancer looks like its pushed out and I know how to tighten my belt bro no need to tell me. It's not to loose.
