1992 yj - JeepForum.com
post #1 of 5 Old 09-01-2009, 08:24 PM Thread Starter
baldone
1991 XJ Cherokee
1992 yj
i have a 1992 yj 4.0
the problem is that the air filter is getting soaked in oil.
there is even oil dripping out of the hose that connects the TB and air box.
anyone have any ideas why this is happening?
Cheers
baldone is offline
post #2 of 5 Old 09-01-2009, 08:42 PM
HMUSN
blow by would be my guess.
HMUSN is offline
post #3 of 5 Old 09-01-2009, 08:43 PM
Axl Jack
Valve cover gasket?
94 YJ w/ stuff. All the work/money I put into it, and the comment I get most is my $20 mod: "Hand throttle?!? That's awesome."
Originally Posted by dmcanally View Post
You know you drive a YJ when it is no longer getting older, but slowly becoming brand new part by part.
Axl Jack is offline
post #4 of 5 Old 09-01-2009, 08:43 PM
RedlineRyan
check your ccv and pcv valves on the top of the valve cover buy at your local jeep dealer like 25 bucks
RedlineRyan is offline
post #5 of 5 Old 09-01-2009, 08:59 PM
dbikers
i'm thinking the same thing..yer crankcase is either building up too much pressure and/or your pcv/ccv isn't working properly.
if the ventilation system is working properly then you may want to look at your compression and see if there is blow-by
STUPID HURTS.......OUCH!@#$
dbikers is offline
1992 YJ Headlights - Please Help!!! ryanalexander4 YJ Wrangler Technical Forum 14 09-03-2009 03:24 PM
1992 Yj? case'sjeep YJ Wrangler Technical Forum 5 06-08-2007 10:02 AM
1992 YJ New Engine ronhallam YJ Wrangler Technical Forum 1 06-01-2007 11:47 AM
1992 4.0 Best Clutch to buy mfw1fan24 YJ Wrangler Technical Forum 4 01-17-2005 06:42 AM
1992 YJ I-4? BzJeep YJ Wrangler Technical Forum 3 03-09-2002 12:13 PM
