1992 wrangler brake problems - JeepForum.com
post #1 of 1 Old 06-30-2008, 07:01 PM Thread Starter
mij3
I have upgraded rear disc brakes and front brakes. still have original master cylinder and proportioning valve. 35 in. tires. Bled brakes really good. Shoes and rotors appear to be just ok. Put a brand new master cylinder.
It will slow down but will not stop on a "dime". Will not lock up even in the dirt. The pedal will eventually go to the floor when you push hard enough, like there is not enough pressure to the shoes. No air in system. Does not pull what so ever.
Considering new shoes and rotors. Think it might be original master cylinder and proportioning valve which are for small tires and rear drum brakes.
Any experts out there.
mij3 is offline
2001 Wrangler Rear brake problems. chucksbluejeep TJ Wrangler Technical Forum 43 05-14-2014 03:54 PM
1992 YJ brake problems mij3 YJ Wrangler Technical Forum 3 11-09-2010 10:46 PM
1992 YJ brake problems mij3 YJ Wrangler Technical Forum 4 07-07-2008 09:51 PM
Brake Problems 1990 Wrangler rbares20 YJ Wrangler Technical Forum 1 08-09-2006 02:59 PM
1992 jeep wrangler problems Golddigger YJ Wrangler Technical Forum 18 01-18-2006 06:39 PM
