1992 Timing Problem? - JeepForum.com
post #1 of 2 Old 12-04-2001, 07:48 PM Thread Starter
JeeperJay
I have a 2.5L and I decided to check the timing today because of some idle and fuel mixture problmes I've been having. When I checked it it was way off the map. I know there is no way to manually adjust the timing because it is controlled by the computer. What would cause the timing to be so far off?
Also, what does the computer do to the motor to change the timing? Thanks in advance.
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #2 of 2 Old 12-05-2001, 10:39 PM Thread Starter
JeeperJay
...to be more specific, the timing is very much advanced at idle speed. I've heard things like the camshaft position sensor and the AIS motor could be the root of the problem, although the computer isn't showing any faults related to those things. Another question I had is if the cam sensor isn't working, can I adjust the timing the old fashion way by turning the distributer for a quick fix?
1992 4x4 problem payprviews YJ Wrangler Technical Forum 9 11-18-2014 11:34 PM
Timing, fuel/air problem? Ramon2 YJ Wrangler Technical Forum 3 02-10-2010 10:27 PM
1992 Jeep Wrangler 4 wheel drive problem tcosgray85 YJ Wrangler Technical Forum 2 01-14-2009 11:21 PM
Is mt timing the problem? ElvisV04290 YJ Wrangler Technical Forum 4 03-13-2007 10:54 PM
1992 2.5L timing questions... freakydiver YJ Wrangler Technical Forum 5 08-04-2004 07:03 PM
