1992 Jeep Wrangler YJ - Vibrations around 45mph - JeepForum.com
post #1 of 14 Old 11-05-2013, 09:38 AM Thread Starter
ridgeback_king
Hey guys, just looking for your opinions on the problem here.
I purchased a 1992 Jeep Wrangler about 3 months ago and I'm experiencing some vibrations from below (drive shaft area) when I accelerate between 42mph - 47mph. It does not vibrate unless I'm pressing on the gas.
I've replaced the U-Joints on the rear drive shaft and it calmed the vibration down a little bit, but it's still there.
I've taken the jeep to three separate mechanics and they said they weren't able to find anything wrong with the rear driveshaft or steering components. One guy recommended that I find someone to balance the drive shaft.
The tires are pretty worn, and need to be replaced soon... but I don't think they are the problem, because they'd vibrate regardless of whether or not I'm pressing the gas... right?
Everything is stock from what I can tell.
No lift kit.
30" tires.
I'm thinking about replacing the drive shaft all together. Would it be pointless to get a rear drive shaft with a SYE even though I don't have a lift? I want to add a 2.5" lift in about a year or so.
I just want to remove the vibration before I do anything.
Thoughts?
ridgeback_king is offline
post #2 of 14 Old 11-05-2013, 10:37 PM
jeepyj13
Check you trans mount to see if it's worn out and motor mounts as well just to rule that out.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #3 of 14 Old 11-06-2013, 04:43 AM
SeanB95YJ
^^^ what he said to start with
but given you're reporting vibes on accelleration indicates your pinion might be just a tad too high, that on acceleration, the pinion is "climbing" throwing the angles out of whack - and that wouldn't be evident to a mechanic just looking at the jeep sitting on the ground (or up on a lift)
also for your other question... no, it wouldn't be pointless to go SYE even with no lift... the slip yoke is a weak link - get rid of it
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #4 of 14 Old 11-06-2013, 08:39 AM Thread Starter
ridgeback_king
Thank you both for the suggestions. I know the motor mounts look great, but I'm not sure about the tran mount. I'll take a look.
As far as the pinion being too high, are there any tests or particular ways of checking to confirm this? I'll google and research, but I figured I'd ask.
Thank you guys for the help!!
post #5 of 14 Old 11-06-2013, 08:49 AM
SeanB95YJ
yes... a cheap ($5-10) magnetic base angle finder available at most hardware stores
for a stock driveshaft (single u-joint at each end with slip-yoke in back of T-case) you want the pinion angle to be parallel with the T-case output. if it is currently parallel, then you'd need to shim the pinion down a degree or two to account for the pinion climb during accelleration I mentioned above.
swap/build thread:
post #6 of 14 Old 11-06-2013, 10:48 AM Thread Starter
ridgeback_king
Gotcha!
Just a quick question. Does a SYE usually remove problems with pinion angles if they exist?
I obviously want to be sure that the angles are good, just a thought.
Thanks!
post #7 of 14 Old 11-07-2013, 05:08 PM Thread Starter
ridgeback_king
Here's the right and left of the mount... I'll be replacing this mount regardless this weekend, but just wondered if you guys think it's the culprit.
post #8 of 14 Old 11-07-2013, 10:09 PM Thread Starter
ridgeback_king
Well I went ahead and installed a new transmission mount and no luck gettin rid of the vibration. The existing mounts looked very old, but probably still did their job.
Next step, get some readings on these driveline angles and we'll see from there.
Thanks for the help so far.
post #9 of 14 Old 11-10-2013, 04:02 PM Thread Starter
ridgeback_king
Had a pretty busy weekend and couldn't find time to take the rear drive shaft off for some angle measurements, but I took a quick photo and, in photoshop, placed some red lines where I estimate the angles to be. Take a look for yourself. It's hard to see this when you're under the Jeep, but with a photo it makes a lot more sense.
Does look to you guys like my pinion angle is too low?
post #10 of 14 Old 11-10-2013, 08:24 PM
squishy
Looks to me your springs are starting to invert. Which changes the dline angles. And before you throw money at a new dline just to lift the jeep and need another one try getting your current one balanced. It's not to expensive.
squishy is offline
post #11 of 14 Old 11-10-2013, 08:42 PM
SeanB95YJ
with a stock driveshaft, the output of the Tcase should be parallel to the pinion.... so given your pic (red lines) your pinion is too low and needs to come up. I made a quick add to your pic to show what the angle roughly should be... the yellow line is parallel to your Tcase output red line
swap/build thread:
post #12 of 14 Old 10-16-2014, 02:03 PM
OFWGKTA
Attachment 832858
I have the exact problem, I just recently lifted my jeep, and my shaft is at the same angle.
What exactly would I need in order to fix that? It's causing MASSIVE vibrations at high speeds, and only when i'm accelerating.
I have yet to get an alignment, but I have an appointment for one this weekend, and if that doesn't fix it I'm certain it's this.
OFWGKTA is offline
post #13 of 14 Old 10-17-2014, 11:39 AM Thread Starter
ridgeback_king
Yeah, I was unable to solve my problem. I don't have a lift on my Jeep. It's stock suspension. I've had the transmission rebuilt. I've had new tires put on.
Still have the same issues.
No clue what to do. Jeep just gets a pulsing vibration at 42-47 mph.
When my transmission was rebuilt, the mechanic told me that the bearings in the transfer case looked pretty bad. Would something like that create a vibration at 42-47 mph?
post #14 of 14 Old 10-17-2014, 12:24 PM
Mike Romain
I had a weird driveline vibe like that on acceleration I couldn't pin down for a long time. Turned out to be my fan clutch going bad. Might be worth a check.
Mike
Mike Romain is offline
