1992 Jeep Wrangler, Wont Start, No Spark - JeepForum.com
post #1 of 14 Old 01-16-2015, 08:13 AM Thread Starter
bigjeepman
1992 Wrangler 4cyl 5 speed.
Will crank for days, no spark, Power going to coil, no spark coming out.
Coil, Distributor Pickup and Cranskahft position Sensor are all brand new. Check engine light comes on when key is turned on, goes out after a minute or two. When I do the engine code procedure it Has shown code 54 repetitively since I replaced distributor pickup. All fuses are good. I have swapped the ASD relay with another working relay.
I always thought if the check engine light comes on it signals the PCM is good
Any ideas? I have turned wrenches on jeeps for years and have never had one this frustrating. Im at a loss. I have read everything under the sun on what it could be. I have spare, known good pickup, cps, and coil at my disposal.
1992 YJ WRANGLER
1998 GRAND CHEROKEE
bigjeepman is offline
post #2 of 14 Old 01-16-2015, 04:42 PM
andyldavis
Code 54
Code 54> no cam sync signal seen at PCM. Bad wire, bad cam sensor.
andyldavis is offline
post #3 of 14 Old 01-16-2015, 06:34 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Unplug the VSS sensor from the tranny. Then attempt to start it up. If it does the VSS sensor is NG.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 14 Old 01-29-2015, 08:32 PM Thread Starter
bigjeepman
Still need help. I unplugged the VSS with no change.
Removed ASD relay and replaced with another.
Tried cranking and I'm getting nothing. I check the codes and it is showing camshaft position sensor (under distributor), replaced it and try again. Same thing. At this point I have checked all fuses, I've ensured the distributor shaft is turning.
I need help. Anyone have any ideas?
post #5 of 14 Old 01-30-2015, 07:14 AM
Que89YJ
Big, do a battery reset to clear all the codes crank it and recheck codes and post them. Did you replace the pickup or the entire distributor?
Que89YJ is online now
post #6 of 14 Old 01-30-2015, 11:22 AM Thread Starter
bigjeepman
Que, I have done that and still get the pickup coil code.
I just replaced the pickup. I Have power going into the coil but nothing coming out. Coil is brand new as well. Cps is new.
post #7 of 14 Old 01-30-2015, 11:31 AM
Que89YJ
First things first do you have a meter? Also basics, the ecu is not receiving the pulse. Look at the connection on the pickup and make sure there are no pushed pins when you put the connectors together. Also pull the cap and make sure the rotor is spinning when you are cranking. The gears on the distributor have been known to fail. We will get you going.
post #8 of 14 Old 01-31-2015, 06:23 AM Thread Starter
bigjeepman
I do have a meter. The rotor does turn, I pulled the distributor because the pickup resembles a newer pickup that uses the two screws that hold the cap down to retain it. I got the one that the parts stores advise as a replacement. Going to disassemble the distributor today and put the replacement pickup in.
post #9 of 14 Old 01-31-2015, 09:20 AM
Que89YJ
Consider the entire setup with the distributor and pickup. They are about 60
Post what happens
Fault codes:
Mean Max pics of everything:
No Start:
post #10 of 14 Old 02-01-2015, 06:15 PM Thread Starter
bigjeepman
Replaced distributor and it fired right up. I'm all good with that but don't understand why. The distributor turned and everything was fine. Makes no sense to me, but non the less, it runs.
Thank you for your help
post #11 of 14 Old 02-01-2015, 08:06 PM
Mark05059
there is a pickup in the distributor.. sounds like yours was bad... when you changed the distributor you changed the pickup inside it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 14 Old 02-02-2015, 04:04 AM Thread Starter
bigjeepman
I had repaced the pickup 3 or 4 times already. No big deal just puzzles me
post #13 of 14 Old 02-02-2015, 04:31 AM
Mark05059
well maybe it wasnt the pickup then... but was obviously something internal to the distributor
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #14 of 14 Old 02-02-2015, 04:11 PM
Que89YJ
I get it right every now and then.
Fault codes:
No Start:
