1992 jeep wrangler maint.reqd. light - JeepForum.com
post #1 of 6 Old 11-13-2005, 01:20 PM Thread Starter
bohunk
I have a 1992 wrangler that has a Maint. Reqd. light on at all times the unit has 84000 miles and I from what my service manual tells me at 82000 it will set this light so that you change the o2 sensor do not have the electrical heating/ac & emissions factory manual which would tell me how to reset light in dash does anyone know this procedure also if any one knows or has one of these manuals would like to purchase it? Thanks
bohunk is offline
post #2 of 6 Old 11-13-2005, 03:24 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Under your dash to the right of your steering column is a small clear plastic box with gears it's the timer just disconnect it or pull it out completely. All it is there for is toget you back to the stealership sop they can pick your pockets. If you have sta emission testing for your sticker they will tell you when your O2 sensor is bad or you CEL will come on. here a picture of it:
http://laybackman.home.comcast.net/timer.jpg
laybackman is offline
post #3 of 6 Old 11-13-2005, 04:13 PM Thread Starter
bohunk
clear box
Looked for box under dash and did not find it is it hidden behind something?
bohunk is offline
post #4 of 6 Old 11-13-2005, 04:48 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
When I found mine it was already "dangling" a bit. Yours is tucked up under the dash by the right side of the steering column. It may be attached by velcro to a flat plate or the lower edge of the dash but it is there.
post #5 of 6 Old 11-13-2005, 11:08 PM
Jayeep
Yeha its so they can pick your pocket
I bought a one owner 92 YJ 4.0L HT with 215 000 kms on it. The check engine light was on, and the guy said it had been on since 70 000 kms. The only thing that buddy had done to this Jeep was replace some belts and hoses. Nothing else other than the basic stuff. Never had taken it into the dealer after he purchased it and from what eye saw it was used alot but the body was still in good shape. I sold it with the light on, and the Jeep still had not seen the dealer since 1992. This was in 2004. You hear of all those mysterious things that happen after the Jeep hits the Stealer. Crooks is what they are, they should be charged. I think Jeeps reliability history is bad 1. because the abuse they see [ crazy ] and crooked dealers [ Jeeps are so easy to screw around with ]. It makes you wonder.
Oh yeah, buddy never even changed the fuel pump or filter. Jeep had tons of power but the valves were going, making it sould like a diesel.
Jayeep is offline
post #6 of 6 Old 11-14-2005, 11:19 AM
Wif
Wif's Avatar
Reset is dealer only (as far as I know). I would either disconnect the timer unit or remove the bulb.
Formally 88Jeepster
Who's in front ?
Ridin' topless again .. sweet !!
Wif is offline
Maint Reqd?? PFP YJ Wrangler Technical Forum 12 04-27-2008 02:27 AM
maint reqd light trimental43 YJ Wrangler Technical Forum 4 01-17-2008 04:59 PM
anyone know how to get rid of maint. reqd. light in a 92yj? YJRomeo YJ Wrangler Technical Forum 24 12-27-2007 01:35 PM
How do you turn off the Maint Reqd Light? Antelope YJ Wrangler Technical Forum 6 11-15-2004 10:34 AM
FS 1992 Jeep wrangler iamthemellowman YJ Wrangler Technical Forum 3 03-22-2004 11:44 PM
