1992 2.5L lifters inspection and cleaning. - JeepForum.com
post #1 of 2 Old 12-03-2011, 08:05 PM Thread Starter
Tyd
I've read a lot of stuff about clicky/tappy lifters and rockers in wranglers. I pulled them out of my 2.5L to take a look at them because i recently had a big clicking noise appear. The lifters are a just starting to get concave, so ... new lifters and camshaft soon. (I could actually look down with a flash light into where the lifters were and see the cam wear. Not terrible but there.)
But!, I cleaned the oil muck off them with a brass brush as well as cleaned the oil paths in the rockers and guides and ... clicking is highly reduced / gone. It will come back as the lifters and cam wears I figure. But hey ... removing them was easy (at least in the 2.5L) ... gives you a good idea about your camshaft health ... and may help.
p.s. here's a nice argument i found for why you need to replace both the lifters and the cam. Go down the page to "Replacing worn tappets and cams." http://www.v8engines.com/engine-4.htm#v8gen Basically boils down to: If your lifters are worn , your cam is worn. If you put new lifters on a worn cam, the cams going to wear them back down in a hurry.
p.s.s. Make sure if your going to pull your lifters out with a lifter removal tool, the tool has a real good grip on the lifter when you pull. If you drop them while you're pulling them up out of the engine you get to chase them around down there and try to stand them back up so you can get a hold of them again. REALLY fun. ... Not that I made that mistake ... but ... i knew this guy who had a friend who did ... just saying.
Last edited by Tyd; 12-03-2011 at 08:06 PM. Reason: seems i can't post pictures. removing links and references. bummer.
Tyd is offline
post #2 of 2 Old 12-03-2011, 09:22 PM
moonshinefuel
I remember putting new lifters in my last engine, and priming them with a small oil gun. When they are primed from pumping a small amount of fluid into the lifters, you hear a small snapping noise of the diaphragm inside, indicating its primed.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
1992 yj , 2.5l , camshaft , lifter
Lifters rogasm TJ Wrangler Technical Forum 7 03-22-2009 04:08 PM
I think it's my Lifters Randy77358 YJ Wrangler Technical Forum 5 03-04-2009 12:07 PM
lifters and cam NPerry05X TJ Wrangler Technical Forum 4 11-15-2007 03:40 PM
Lifters WTF yarosig YJ Wrangler Technical Forum 14 02-18-2007 12:55 PM
Lifters ToolMan YJ Wrangler Technical Forum 3 05-16-2003 08:22 AM
