1991 YJ 4.0L dies when hot (tough one) - Page 2 - JeepForum.com
post #16 of 21 Old 10-05-2013, 07:15 AM
WDNewman
Originally Posted by Akumakis View Post
Tried a few things, but not the CSPS yet.
Testing for resolution is tough. It takes a while to heat up to the point of quitting, and we tend to stop for beers when out 4beer4ing. Even enough downhill seems to give it sufficient time to rest.
As I have time to try things and test properly, I'll keep posting on it.
Thanks, all.
My money is on the CSPS. Your symptoms are exactly what mine were until I replaced the Crank shaft position sensor. Has not had a problem since.
WDNewman is offline
post #17 of 21 Old 10-09-2013, 07:59 PM Thread Starter
Akumakis
Discussion was re cam pos sensor, not crank pos sensor. I replaced the latter prior to initial post; no effect. I see the cam pos sensor is in the distributor; I'll dig one out of a wrecking yard or buy one, and report back.
Akumakis is offline
post #18 of 21 Old 11-02-2013, 07:43 PM Thread Starter
Akumakis
Vss
Not the VSS. I disconnected it entirely, no effect at all. Doesn't run bad...I read that the VSS only affects idle when you come to a stop. In any case, no help there.
Bought a new distributor, which I've never replaced before, and contains the new cam pos sensor. I'll install and see if i can make it quit again. Cold weather making it trickier to test.
Akumakis is offline
post #19 of 21 Old 11-02-2013, 09:03 PM
Que89YJ
Don't rule out the vss. There is one other possibility. Check the writing harness that goes down the firewall behind the battery that supplies the vss. It's a possibility that it is shorting. If the vss shorts it will take out the voltage for the vss. Mine was burned by the manifold and shorting.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #20 of 21 Old 11-03-2013, 07:15 AM
Cajun90YJ
I have seen the pcm cause this issue, on 3 diff Chryslers, 95 jeep 4.0, dodge Dakota and an 06 TJ. The pcm would get hot after driving or engine running and the pcm would lose a ground internally. They would throw cam and crank codes, and a few others. it can throw any that the pcm grounds. You can usually cause it to die (after you get it cranked following the first stall) by tapping on the pcm with a screwdriver handle or something. DON'T BEAT IT! Light taps should do it if that is the cause.
Cajun90YJ is offline
post #21 of 21 Old 11-04-2013, 12:57 PM Thread Starter
Akumakis
This is interesting. When the problem first occurred I suspected a sensor, or the ECU. I'll try your trick.
1991 Jeep YJ Renegade 4.0L
Akumakis is offline
