1991 YJ 4.0 No Power to ignition switch ??? - JeepForum.com
post #1 of 16 Old 07-14-2007, 10:33 AM Thread Starter
Jeeperjoey
Hello, I hope someone can help, I have a 91 yj with 4.0 . There is no power to my ignition switch. Everything not assosiated with the switch works. Starter will even turn by jumping selonoid. Any help would be great, Im not a big electronics guy.
Jeeperjoe
Jeeperjoey is offline
post #2 of 16 Old 07-14-2007, 12:27 PM
Brown Dog
Vendor
Brown Dog's Avatar
Chceck relays and fuses in the relay box under the hood, in front of the battery.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #3 of 16 Old 07-14-2007, 12:33 PM Thread Starter
Jeeperjoey
Did that, all fuses good and show power on both sides, relays i just switched them around several times and nothing. Thanks
post #4 of 16 Old 07-14-2007, 01:00 PM
Brown Dog
Vendor
Brown Dog's Avatar
I guess it's time to check for continuity then.
Brown Dog Offroad
91YJ 2.5
2" BL
4.5" Superlift SL
AA SYE
Best Top seats
"Family" roll bar
post #5 of 16 Old 07-14-2007, 01:11 PM Thread Starter
Jeeperjoey
I guess its off to the shop for me then, very mechanical, but not electrical.
Thanks again
post #6 of 16 Old 07-14-2007, 01:21 PM
dmcanally
dmcanally's Avatar
2011 JK Wrangler
I had a problem exactly like this with my 89. It turned out to be a fusable link was burned out. You might want to check those out.
Red Jeep Club # 383
, _____
/l
,[___],
l--L --[]lllll[]-
()_) ()_)-o-)_)
dmcanally is offline
post #7 of 16 Old 07-14-2007, 04:20 PM Thread Starter
Jeeperjoey
do you know where the link was, so without taking off all the covering I might find it. I did not see any uncovered , I even pulled the fusebox out.
post #8 of 16 Old 07-14-2007, 04:35 PM
jaw41272
jaw41272's Avatar
Nuetral Safety switch, I don't believe 91's have fuseable links, they should have MAXI fuses under the hood instead. Try swapping out your starter relay with one of the others, that could cause it as well. But when I had that problem my nuetral safety switch was the culprit. I have an auto tho, don't know what you've got.....
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #9 of 16 Old 07-14-2007, 05:47 PM Thread Starter
Jeeperjoey
I got a stick, and wont work with clutch in or out or tranny in or out of gear. I dont even have assesories when I turn key before starting. No power getting to my ignition switch, but power at fuse for it under hood. I also tried switching the relays.
Thanks e1
post #10 of 16 Old 07-14-2007, 06:57 PM
pasinbuy
I did not check my manual, but if you checked the switch hot wire and found no power to it. Then trace that wire back. You manual will help with color codes.
Also if you think it is the switch. ( I have repaired and replaced many ign switches on motor cycles and a car or two ) Try turning the switch back and forth to close the connection. If it is the switch it should hit 1 in 25 times.
If your dash works when you turn on the switch, I would guess it is the starter selinoid.. I have to push in my clutch in order for my 94 to start, check that switch.
pasinbuy is offline
post #11 of 16 Old 07-15-2007, 10:15 AM Thread Starter
Jeeperjoey
anyone know which is the hot wire to the ignition switch ? I just checked them all.
post #12 of 16 Old 07-15-2007, 10:36 AM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
should be the heavy gage red wire. if you've got no power there then double check your maxi fuses again to be sure (it's one of the 40 amps) and if they check out start tracing that wire back to find the break.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #13 of 16 Old 07-15-2007, 10:41 AM
kloppk
The RED one
kloppk is offline
post #14 of 16 Old 07-15-2007, 06:04 PM Thread Starter
Jeeperjoey
Thanks e1 for your help.
I bought the haynes book, found the wire coming out of fuse box under hood and ran new one to the ignition switch, e thing works fine.
Thanks again !!!
post #15 of 16 Old 06-25-2016, 04:06 PM
bvanbeek2
where can i buy a new fusible link? i went a broke mine.
bvanbeek2 is offline
HUGE problem with '87 4.2L - Ignition Switch Power Issues (No power on key turn) jesseleikerjeep YJ Wrangler Technical Forum 11 02-26-2016 04:25 PM
Ignition switch or something else? Key on + no power Diabl0 TJ Wrangler Technical Forum 64 03-13-2012 05:56 PM
No power to my ignition switch ImpactFabWorks YJ Wrangler Technical Forum 9 04-01-2009 11:30 AM
power loss when turning ignition switch?? JKNIPE2000 YJ Wrangler Technical Forum 7 04-19-2005 01:14 PM
Loose Switch in Ignition Cylinder (Power for Radio) czar97 TJ Wrangler Technical Forum 1 07-24-2004 08:33 PM
