1991 Jeep YJ Chugging, HELP! - Page 2 - JeepForum.com
post #16 of 28 Old 08-07-2014, 10:03 PM Thread Starter
cgh498
I doubt it would be the fuel pump because I'm able to accelerate quickly now without much struggle. I believe it is sensor related because when it does bog down and stop, when idleing the rpm's range from 500-1500 without touching the pedal.(it moves around on its own)
Also it isn't my cat because right before the cat there is a rust hole so if exhaust needed to, it could exit through there.
Im going to take a look at, clean, and if needed replace the CPS next.
cgh498 is offline
post #17 of 28 Old 08-08-2014, 04:42 AM
Que89YJ
It could be your cat.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #18 of 28 Old 08-08-2014, 01:10 PM
tjhall
I'm working with the OP on this issue and will add an update since he is at work. We replaced the crankshaft sensor to no avail. I went back and checked the fuel pressure again, this time while driving around. When the yj started to stumble the pressure dropped from 30 to 15 psi. let me restate that, I would drive and I'll be at 30 psi and slowly start to drop. Once the pressure got under 20 is when the car started having issues.we already replaced the fuel filter, so does this look like the fuel pump is at fault?
tjhall is offline
post #19 of 28 Old 08-08-2014, 03:59 PM
tommy12241
Yes. Definitely the pump
tommy12241 is offline
post #20 of 28 Old 08-08-2014, 05:25 PM
Que89YJ
Fuel pump.
Fault codes:
No Start:
Que89YJ is offline
post #21 of 28 Old 08-08-2014, 08:18 PM
Delawdude
Couldn't be the fuel pressure regulator? Agree it sounds like the pump is not pushing the fuel fast enough to keep up with demand. But not im sure if the FPR could cause similar symptoms?
Delawdude is offline
post #22 of 28 Old 08-08-2014, 08:20 PM
Que89YJ
The regulator will always fail high. The diaphragm rips and you see source pressure at the rail.
Fault codes:
No Start:
Que89YJ is offline
post #23 of 28 Old 08-09-2014, 01:23 PM
tommy12241
I agree. High fuel pressure is generally the sign of a bad regulator. (I say generally because there are no absolutes). But ive never seen a bad regulator create low pressure
post #24 of 28 Old 08-09-2014, 01:27 PM
Delawdude
Makes sense. Was curious so thought I'd put it out there.
post #25 of 28 Old 08-09-2014, 06:29 PM Thread Starter
cgh498
Solution: I replaced the fuel pump, fuel strainer, and the fuel filter. The fuel filter just needed replaced because of regular buildup, and the fuel pump had little to no output power. Also the fuel strainer had metal shavings inside from the the broken down fuel pump.
Thank you so much for everyone's quick and helpful input
cgh498 is offline
post #26 of 28 Old 08-09-2014, 07:26 PM
tommy12241
No problem. Glad we could help a fellow jeeper in need
post #27 of 28 Old 08-09-2014, 09:04 PM
Delawdude
Thanks for posting the fix!
post #28 of 28 Old 08-11-2014, 06:38 AM
mike134
Awesome! Thanks for updating with symptoms and solution!
mike134 is offline
1991 yj , 2.5 liter , 4 cylinder , jeep yj
