1991 Islander Fuel Tank Woes - JeepForum.com
post #1 of 6 Old 11-23-2011, 03:32 PM Thread Starter
LonnieD
Replaced leaking tank with new aftermarket. Filler neck will not clear the frame and touches the crossmember above. The new tank is correct model but not exactly identical to OEM. Neck is 1" shorter, tank height is 1" more and length (width? .. axle to axle dimension) is 1 1/2' shorter. Any ideas on a work around? Thanks
LonnieD is offline
post #2 of 6 Old 11-23-2011, 03:51 PM
94chb
put driver side of tank up in first then passenger side
94chb is offline
post #3 of 6 Old 11-23-2011, 04:12 PM Thread Starter
LonnieD
Thanks for the quick reply. I didn't explain my dilemma correctly. I installed the replacement tank and tightened all of the tank/skid plate bolts. That is when I discovered that the filler tube neck was butted up to and its end flush with the crossmember. Can't get a clamp over that neck, much less the filler hose. When I dropped the tank again, the sending unit tubing had rubbed a mark on the undercarriage under the cargo area as well. I am thinking of shimming the skid plate edges and installing longer bolts, but wonder if that will expose the outlet hose and fuel pump electrical to excessive moisture/debris. Thanks again!
LonnieD is offline
post #4 of 6 Old 11-24-2011, 06:11 AM
mrmud4x4
Are your body bushings squished flat? When I did new daystar body lift bushings that are 1" taller, that gave me easy access to the gas tank fill/vent hose clamps. They were not behind/against the rear frame anymore.
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #5 of 6 Old 11-24-2011, 08:34 AM Thread Starter
LonnieD
Well ... Duhhh! Thanks mrmud4x4 - that is the answer!! I just ordered the body lift bushings. Old girl has 300K miles on her and the stock bushings are shot. I appreciate the solution and look forward to more advice as we spiff up the YJ.
LonnieD is offline
post #6 of 6 Old 11-24-2011, 09:24 AM
mrmud4x4
Get hold of a 4 or 4.5" grinder (like a Makita) that will accept the cutting disc's......I am pretty sure that you will need to cut out some body metal to get at the top of the bushing bolts. I had to cut three areas.....under the drivers seat, and the two rear ones - hidden behind the rear tire well plastic. Wear safety goggles......
The top bolts have holders in there that will be rusted out.....the nuts/bolts that spin will be the ones that you will have to access on top.....some you can get to, others are under body metal.
We cut flaps, then I cut out some aluminum daimond plate pieces to cover the cut out areas, bend the flaps back and use self tapping screws to mount your daimond plate covers over the cut out area. Use rustoleum spray paint on your cuts first, and some gasket goop when you place the daimond plate covers over the area....
mrmud4x4 is offline
1991 islander looking for lift kit Mickele_YJ YJ Wrangler Technical Forum 1 10-18-2010 11:05 AM
Fuel Tank Woes darkpony YJ Wrangler Technical Forum 1 09-28-2008 07:56 AM
1991 YJ Fuel Tank Skid Plate JaySpencer66 YJ Wrangler Technical Forum 11 07-16-2008 11:46 AM
1991 YJ Fuel Tank Needed TheBrainB YJ Wrangler Technical Forum 8 03-24-2008 12:53 AM
