1991 5 speed swap problems? - JeepForum.com
post #1 of 5 Old 11-13-2013, 07:22 PM Thread Starter
Moeller94
I'm trying to do a swap in my YJ. engine is aa 88, 5spd trans is an 92
i got a t-case from a TJ,
My problem is the starting sensors from the old auto, has anyone every done this swap?
with any info will help me alot.
Thanks for reading
Moeller94 is offline
post #2 of 5 Old 11-14-2013, 05:54 AM
Que89YJ
Are you staying with the carb? If you are then the sensors dont mattery. Tcase should have the same bolt up for the speedo, the switch for the reverse lights and clutch, and if you are carbed the crank sensor on the bell housing does nothing and can be removed.
Que89YJ is offline
post #3 of 5 Old 11-14-2013, 06:30 AM
mike_breaker_5
if your doing a trans swap anyhow... maybe you would like tot look for a 94-95 bell housing?
this will allow you to have an external slave cylinder.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #4 of 5 Old 11-14-2013, 09:58 AM Thread Starter
Moeller94
I am leaving it carbed, i didnt change out the steering column, so it doesnt know when its in "park" to start, im going to by-pass the key with a push start switch
post #5 of 5 Old 11-14-2013, 01:08 PM
mike_breaker_5
you could always just shift the selector into "D" and then remove the shifter lever from the column. this will have you always ready to turn the key. a used manual column should be fairly inexpensive at your local salvage yard.
if the east stroudsburgh you are from is in lehigh valley PA i could probably mail you my old beat up manual tilt column if you paid shipping. it's pretty messed up but you could make one useable column from the 2. i won't have it available for a little while yet, as i have to take it out first.
