1990 YJ Steering Column - JeepForum.com
post #1 of 1 Old 03-24-2012, 11:40 AM Thread Starter
dcook35
Does anyone know what steering column is in the 1990 YJ with 5 speed and 258 6 cyl? I am needing some new parts to rebuild my column and am missing the lower plastic covering. I am under the impression that it is a GM column from the research that I have done and need to verify what it is exactly. Steerings columns galore .com lists it as a 80 - 94 Saginaw GM. Is this correct? has anyone ever had any dealings with this company?
I may just go ahead and buy a rebuilt column from them if they are reputible.
Thanks in advance for any input.
dcook35 is offline
Looking for a steering column for 89 wrangler, column shift!!! Where should I look? ChumSlam YJ Wrangler Technical Forum 1 09-15-2010 09:52 AM
Will 00 TJ steering column interchange with 05 TJ column JWhip TJ Wrangler Technical Forum 11 07-23-2010 12:27 PM
1990 yj steering column parts needed! jasoncpeel1 YJ Wrangler Technical Forum 2 05-16-2010 08:09 PM
Power Steering Fluid (Miniscule) Leak from Steering Column??? JRostron30 TJ Wrangler Technical Forum 3 07-09-2009 11:20 PM
Upper steering column for 1990 with tilt jbolty YJ Wrangler Technical Forum 2 01-20-2009 02:22 PM
