1990 YJ starting problem! - JeepForum.com
post #1 of 17 Old 03-06-2010, 12:02 PM Thread Starter
YJ_Dan
I replaced the starter in my YJ because when I turn the key I get one click and nothing else? So I replace the starter and same thing?????
Any ideas what I should check next?
YJ_Dan is offline
post #2 of 17 Old 03-06-2010, 12:25 PM
pman
Have you checked battery voltage and connections??
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3 of 17 Old 03-06-2010, 12:40 PM Thread Starter
YJ_Dan
I don't think it's the battery everything else works, even tried jumping it to make sure. Would it be the ICM if when I turn the key I only get one click and the starter won't turn?
Plugs, wires, distributor are all about a year old.
It would not start intermittently and now nothing?
YJ_Dan is offline
post #4 of 17 Old 03-06-2010, 01:27 PM
pman
Dan-
I would still pull your batt. cable connections, clean them for good measure, and replace. Many times it's the simplest things that cause problems (ask me how I know!!). Your battery can measure 12v and if the battery cable connections are poor, you can have similar problems.
The Ignition modules on the 4.2L rigs are notorious for crapping out (I'm on my 3rd one). My personal experience with ICM problems has just been loss of fire to the coil (engine will turn over but never start and won't receive juice to the coil). Still could be a possibility, as I believe the ICM on your 4cyl is different than mine.
In your last sentence, you say "It would not start intermittently"...does this mean it always started right up, or did you mean to say "It would start intermittently"?
Did you have the original starter bench tested? I'd still check for proper power to the starter before moving on.
pman is offline
post #5 of 17 Old 03-06-2010, 01:46 PM Thread Starter
YJ_Dan
It used to start fine and once in a while this would happen. But it would eventually start. I'm going to bring the starter and ICM down to have it bench tested.
YJ_Dan is offline
post #6 of 17 Old 03-06-2010, 01:54 PM
pman
Ahhh...hmmm. I think you're doing the right thing by taking both parts to have them tested, then. I know on one occassion my ICM would give me intermittent problems (literally would kill my engine while riding down the road, then would take a few minutes to crank back up) before finally giving up the ghost.
I hope I don't sound like I'm questioning your intelligence, but I really would pull the battery cables off, clean and reinstall. It can't hurt. Keep us posted.
pman is offline
post #7 of 17 Old 03-06-2010, 02:09 PM Thread Starter
YJ_Dan
That's what I'm going to do in a minute, parts store closed for the day. I'm open to any and all suggestions, so no worries.
YJ_Dan is offline
post #8 of 17 Old 03-06-2010, 03:37 PM Thread Starter
YJ_Dan
Ok, so I jumped both starters I have and nothing. I bypassed the solenoid (spelling?) and both engaged and spun. So i have to go buy a new solenoid and will sell the other starter with the stipulation that it needs a solenoid, unlike they guy who sold me his.
YJ_Dan is offline
post #9 of 17 Old 03-09-2010, 04:06 PM Thread Starter
YJ_Dan
I had my ICM tested today and it is shot, so hopefully that will do it. Now on to find one that isn't $150.
Thanks for the help everyone.
YJ_Dan is offline
post #10 of 17 Old 03-09-2010, 04:48 PM
giggityjeeper
for future reference if your starter is toast you wont even get a click..unless it has a dead spot, but you will notice that as it will prolly graon..
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #11 of 17 Old 03-09-2010, 06:08 PM Thread Starter
YJ_Dan
Cool thanks.
YJ_Dan is offline
post #12 of 17 Old 04-01-2010, 12:19 PM Thread Starter
YJ_Dan
I had the ICM tested and it was bad. Spent $110 for a new one and still nothing? I'm thinking it might be the coil but am having a hard time finding a place to bench test it. Any ideas?
YJ_Dan is offline
post #13 of 17 Old 04-01-2010, 01:26 PM
Uberjeep
I have a 91 4.0 that uses the crank position sensor (on the bellhousing), and the cam position sensor(on the distributor) to activate the ICM. Had an issue with a bad connection to the CPS that resulted in the same condition. Any idea if your motor has both of these sensors? I have no experience with 4.2's to know, but maybe worth a check?
Originally Posted by 2003Rubi View Post
Make sure you get a sticker that says "Jeep" in Japanese lettering, that mod is good for about 20-25 hp right there.
My Jeep has only ever killed three things. A deer, a dog, and my wallet.
*retired* Low Output Jeep Club # 135
Uberjeep is offline
post #14 of 17 Old 04-01-2010, 03:39 PM
88YJtoCJ
is that FI or Carb'd... I would say check your ground cables, especially for the starter and coil.
Also, have you thought about replacing the ignition switch?
88YJtoCJ is offline
post #15 of 17 Old 04-01-2010, 05:51 PM
tonylax48
i had this same problem there is a connection that is bad ill run out and snap a pic of it for you.
1990 YJ soon to be 4.7L, auto, d30 4.11 w/ spartan locker, ford 8.8 4.11 open, sye, 4in RC 2in BL
tonylax48 is offline
1990 4.2 L starting problem jlbl9448 YJ Wrangler Technical Forum 15 10-17-2009 08:24 AM
1990 YJ 2.5l Not Starting ANJEEP69 YJ Wrangler Technical Forum 13 06-30-2008 11:15 AM
1990 2.5 Turns over, not starting Devaclis YJ Wrangler Technical Forum 5 02-14-2007 02:10 PM
Carb/Starting problem - 1990 4.2L zcanon YJ Wrangler Technical Forum 2 05-05-2005 10:25 PM
1990 YJ clutch problem ? THEKNEEBITER YJ Wrangler Technical Forum 1 02-06-2004 07:59 PM
