1990 YJ smells like Gasoline!!??? HELP - JeepForum.com
post #1 of 6 Old 11-27-2013, 06:30 AM Thread Starter
bisco1
I just picked up a beautiful 1990. It runs amazing and is almost rust free!! however, it smells like Gas?!?! I am not too engine savvy so looking to you all for help.
any ideas??
Thanks Bill W.
bisco1 is offline
post #2 of 6 Old 11-27-2013, 06:48 AM
Rproject
1987 YJ Wrangler
A little help? Engine? Carb versus fuel injection? If carb - any clue as to OEM or aftermarket and which aftermarket might be on it?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 6 Old 11-27-2013, 07:35 AM
bpounds
bpounds's Avatar
If it smells like raw gas, you've got a leak. Use your nose to find it. Likely locations are:
Lines on top of gas tank
Connections to the fuel filter
Connections to the fuel pump (for carb models)
Connection to the carb/throttle body
Charcoal canister/vapor recovery lines
Also check for the smell of gas in the engine oil, which could mean a bad fuel pump (for carb models)
And last but not least, bad or loose gas cap. That one happened to me. I smelled gas for a couple of days after a fillup. Found that I had not put the gas cap back in place properly. Telltale signs of gas running down.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is online now
post #4 of 6 Old 11-27-2013, 07:41 AM
grandboost98
As well as the roll over valve in the rear passenger corner
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #5 of 6 Old 11-27-2013, 05:18 PM
JCashen
Post some pictures of the jeep and engine bay.
"Drippy"
90 YJ 5.2 Magnum MS3x, D60/GM 10.5", ORI struts, 4 link
JCashen is offline
post #6 of 6 Old 11-27-2013, 05:24 PM
grandzj96
I had the fuel filter line wiggle almost all the way off on mine. That may not be a bad place to start
grandzj96 is offline
