1990 YJ Howell TBI high idle - JeepForum.com
post #1 of 11 Old 03-30-2015, 10:05 PM Thread Starter
oxtail4
Got done with the Howell TBI retrofit onto my 1990 YJ with 258 cid. All is well, good starting, driving all smooth. Idle, however is high, about 1500 rpm.
Looked for vacuum leaks - haven't found any
Tested idle air controller per Howell - jumpered A/B terminals and unplugged, idle still high.
Drilled out idle screw and adjusted per Howell manual - lowered idle down to about 1100 rpm - ran out of adjustment.
Any other ideas out there?
oxtail4
1990 YJ
oxtail4 is offline
post #2 of 11 Old 03-30-2015, 10:55 PM
mike134
how long did you run it for? when the engine is cold, 1100 is about normal. It should drop as it warms up to temperature.
mike134 is offline
post #3 of 11 Old 03-31-2015, 08:57 AM Thread Starter
oxtail4
Starts at 1500, lowers to 1100 at normal operating temps.
oxtail4 is offline
post #4 of 11 Old 03-31-2015, 09:13 AM
jbolty
jbolty's Avatar
Do you have access to an OBD1 scanner?
I had that issue and it's been a few years but I seem to recall it being the MAP sensor.
Call Howell, they are very helpful. The normal tech guy will start firing questions at you so before you call note everything. Timing, what you've done and tested and any other possible adjustments.
jbolty is offline
post #5 of 11 Old 03-31-2015, 10:18 AM Thread Starter
oxtail4
No OBD1 scanner. Is there one you can recommend - I get a lot of hits if I google.
I've talked to Howell. They asked told me to check the IAC - tested OK. I'll try them again and see what they say.
oxtail4
1990 YJ
oxtail4 is offline
post #6 of 11 Old 03-31-2015, 01:19 PM
jbolty
jbolty's Avatar
you need a scanner that will read GM vehicles. The computer will report to the scanner as a late 80s small chevy pickup
jbolty is offline
post #7 of 11 Old 03-31-2015, 01:23 PM
boduke5051
boduke5051's Avatar
Does the Howell come with the GM OBD1 type diagnostic connector? If so, I would think you could read the codes by the check engine light by jumpering the A and B terminals. Or has the Howell system done something different that would cause this to be a bad idea?
Link below:
http://www.obd-codes.com/faq/read-gm...codes-free.php
If you can't be good, be good at it! >:-D
http://www.jeepforum.com/forum/f286/hound-2833082/
boduke5051 is offline
post #8 of 11 Old 03-31-2015, 02:03 PM Thread Starter
oxtail4
If the computer was throwing a code, the check engine light should come on (I thought). When I bypass the computer, I do get the single blink as it is supposed to per Howell.
oxtail4
1990 YJ
oxtail4 is offline
post #9 of 11 Old 03-31-2015, 02:27 PM
jbolty
jbolty's Avatar
if you have a scanner you can read the sensor voltages and get some sense of what's happening that may not be causing a code.
jbolty is offline
post #10 of 11 Old 03-31-2015, 03:42 PM
boduke5051
boduke5051's Avatar
I see where you're going now. I didn't think of that because all of the scanners I ever had weren't nice enough to show actual live data like that.
post #11 of 11 Old 03-31-2015, 05:51 PM Thread Starter
oxtail4
I'll be on amazon tonight to order one.
oxtail4
1990 YJ
oxtail4 is offline
