1990 yj fuel pump - JeepForum.com
post #1 of 6 Old 01-10-2011, 05:10 PM Thread Starter
otr1952
1990 yj fuel pump
where is the fuel pump on 90 yj 6cyl. gas tank? on engine?
Politicians are like Diapers, they get full of stuff and need to be changed frequently!
otr1952 is offline
post #2 of 6 Old 01-10-2011, 05:12 PM
Mark05059
4.0 is in the tank
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 6 Old 01-10-2011, 05:13 PM
rshbutch
its on the passenger side of engine.
rshbutch is offline
post #4 of 6 Old 01-10-2011, 05:17 PM
jbolty
jbolty's Avatar
If it's a 1990 4.2, it's a mechanical pump on the engine.
jbolty is offline
post #5 of 6 Old 01-10-2011, 05:20 PM Thread Starter
otr1952
thanks, i was askin for a friend. if he were to change blocks and stay basicly stock or near, what engine do yall suggest?
otr1952 is offline
post #6 of 6 Old 01-10-2011, 05:38 PM
Yarz
Many poeple have changed to the 4.0L from a newer jeep with good results. That is as close to stock as you can get without using the same 4.2L. A stroker is probably the next closest to stock. Others have done many other engines from fords, chevys, jeeps, etc, etc.. But those don't fit your criteria of staying basically stock. Search around here, and you'll find all kinds of information on swaps
As for suggesting one, I can't help there. I haven't seen/helped with any in person, and it really depends heavily on what you're looking for.
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
1990 White YJ TBI350, SM465, NP231, SOA, RE 1.5" SOA springs, Ford 8.8, D30, 4.10's, JBConversions SYE, XJ shaft, Bilstein 5150s, jb4x4 steering, MORE SS brakelines, 35x12.50 15 MT's, '95 YJ Brake Booster, '78 Grand Marquis MC, ZJ Prop. Valve
Yarz is offline
Replace Fuel Pump or Fuel Pump/Sending Unit assembly? Muratus TJ Wrangler Technical Forum 10 02-09-2012 09:08 AM
1990 jeep YJ 3.9 magnum swap fuel pump issue smaxwell944 YJ Wrangler Technical Forum 1 05-04-2010 07:18 AM
1990 Fuel Tank Gcopter YJ Wrangler Technical Forum 1 02-26-2009 10:04 AM
Fuel pump assembly vs. fuel pump? eclipse27 TJ Wrangler Technical Forum 11 11-11-2008 09:18 AM
1990 Fuel Pump Problem BlackRifle223 TJ Wrangler Technical Forum 1 06-21-2007 07:04 PM
