1990 yj fuel problem - JeepForum.com
post #1 of 3 Old 03-21-2011, 03:49 PM Thread Starter
otr1952
1990 4.2 with webber carb. seems to be running too rich! poor mileage, tried everything I can think of.
fuel cap develops pressure after I dr a mi or so. is this normal?
Politicians are like Diapers, they get full of stuff and need to be changed frequently!
otr1952 is offline
post #2 of 3 Old 03-21-2011, 05:35 PM
mcmud
1983 CJ8
I suppose that you have a vacuum building up in the tank. Check out your tank vent tube to the charcoal canister. If the button cap nipple were to be considered the #1 nipple the tank vent tube would the third. It should be a green flexible tube fitted with a rubber tube to that nipple.
Have you tried to dial in the screws to the recommended settings on the carb...and which one is it?
mcmud is offline
post #3 of 3 Old 03-21-2011, 07:16 PM
superj
mileage is not going to be great with a 34 weber, i have one and am unimpressed with it. its definitely not a 32/36 or a 38. no power and horrible mileage, i feel.
the pressurization, i would check the tank vent
I don't feel like working on anything at this time so i sold my yj.
superj is offline
1990 4.2 new carb, fuel filter, fuel pump barely runs, help. litz YJ Wrangler Technical Forum 18 05-17-2017 10:04 AM
1990 yj fuel pump otr1952 YJ Wrangler Technical Forum 5 01-10-2011 05:38 PM
1990 Fuel Tank Gcopter YJ Wrangler Technical Forum 1 02-26-2009 10:04 AM
1990 Fuel Pump Problem BlackRifle223 TJ Wrangler Technical Forum 1 06-21-2007 07:04 PM
carter carb and fuel problem on 1990 yj sport J_UMPER YJ Wrangler Technical Forum 3 03-03-2005 08:31 PM
