1990 yj compression test results need help - JeepForum.com
post #1 of 5 Old 12-13-2011, 08:54 PM Thread Starter
mangoman123
OK today I did a compression test. My results were
Cylinders 1 2 5 160 Psi
Cylinders 3 4 6 150 psi
Is this good or bad? Should I have the ten pound difference between them?
mangoman123 is offline
post #2 of 5 Old 12-13-2011, 08:56 PM Thread Starter
mangoman123
Oh, its the 4.2l engine. Sorry
post #3 of 5 Old 12-13-2011, 11:10 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Its perfect.
Anything under 120 psi is getting worn, around 120psi average with a 15psi spread you should figure out which end of the cylinder needs refreshed(head/valve job or rings)
One super low cylinder is usually a head gasket (if no racket from the valve train or a busted piston is expected)
under 100psi average the motor needs rebuilt in full
Under 80psi it probably wont run.
ratmonkey is offline
post #4 of 5 Old 12-14-2011, 10:31 AM
oteps
1980 CJ5
Yep those results are good. Are you having an engine problem or did you just want to check compression?
oteps is offline
post #5 of 5 Old 12-14-2011, 04:40 PM Thread Starter
mangoman123
Weird feeling with power demand, like up hills, plus a knocking sound. This thing is killing me on new parts though.
