1990 YJ Body Mount Locations - JeepForum.com
post #1 of 4 Old 11-02-2011, 08:44 AM Thread Starter
szbaren3411
I am getting ready to attempt a 1" body lift on my 1990 YJ. I bought some PB Blaster from AutoZone last night to help loosen the 20 something years of rust and corrosion. I was wondering if anyone had a diagram that shows the location of all the body mounts.
szbaren3411 is offline
post #2 of 4 Old 11-02-2011, 08:45 AM Thread Starter
szbaren3411
post #3 of 4 Old 11-02-2011, 08:54 AM
Que89YJ
Que89YJ is offline
post #4 of 4 Old 11-02-2011, 08:58 AM
jbolty
jbolty's Avatar
just make sure you get the PB on the threads of the bolts. You will have to drill some small holes to do so.
And try loosing the bolts a little at a time over a few days. Spray. Turn. Spray again. Turn the other way. Eventually thay may come loose; or you will get lucky and only break one of the easy to fix ones.
jbolty is offline
body mount , diagram , YJ
YJ Body mount locations mark12010 YJ Wrangler Technical Forum 6 10-12-2016 06:55 AM
Body Mount Bolt Locations (For BL) - Detailed Write-Up W/ Pix CheapSunglasses YJ Wrangler Technical Forum 107 06-20-2016 03:37 PM
Lets see you CB mount locations N2rock JK Wrangler Technical Forum 35 02-04-2010 07:56 PM
TJ body mount locations (pictures?) rikkards TJ Wrangler Technical Forum 3 06-15-2009 03:55 AM
11 Body Mount Locations BRad704 YJ Wrangler Technical Forum 4 01-05-2006 04:00 PM
