1990 yj 4.2 - JeepForum.com
post #1 of 6 Old 06-07-2013, 08:06 PM Thread Starter
zackattack
1990 yj 4.2
Question for the carburetor masterminds. My 1990 Yj 4.2 is having trouble idling. I have already done a few simple things to correct this but I am not having any luck. I tried raising the idle, adjusting the gas/air mixture, and also preformed the "nutter bypass," but yet every time I stop at a stop sign or traffic light, the engine will stall.. My next move is to adjust the choke, and possibly replace the float in the carb. The carb has been rebuilt not even 200 miles ago. I have 163k miles on the 4.2 and it runs great, great pick up, great acceleration, and runs great at a steady speed, but like I stated before the only problem is it wont idle. Any ideas please let me know, thanks
zackattack is offline
post #2 of 6 Old 06-07-2013, 08:29 PM
Old4X
1990 CJ7
http://www.jeeptech.com/engine/carter.html
Have you done this yet? A must do with gasahol today.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 6 Old 06-07-2013, 10:40 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
I had that issue with my carb a few weeks ago I had to replace a vaccum line and adjust the idle speed, and bump the timing it runs smooth as silk now !
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #4 of 6 Old 06-08-2013, 09:02 AM
act3k
I had a slight leak in my egr valve and another in my brake booster that caused my 4.2 bad idle issues . I would do a very thorough check of gaskets and such for vacuum leaks
act3k is offline
post #5 of 6 Old 06-08-2013, 10:13 AM
Beachcruiser
1987 YJ Wrangler
Clean the idle tubes if you haven't already.
probably out breaking stuff.
Beachcruiser is offline
post #6 of 6 Old 06-08-2013, 12:27 PM
snag
2010 JK Wrangler
+1 on pulling the venturi and cleaning the tubes
snag is offline
