1990 YJ 2.5 Factory AC? hose routing - JeepForum.com
post #1 of 3 Old 03-04-2013, 04:42 PM Thread Starter
goodwrenchk29
i need help identifying my ac system. i pulled everything off and put in a box, but some a** stole it all . now im trying to replace it.i feel that it was factory because the wiring i removed for the compressor was plugged into a 6 way connector under battery and ran into 2 relays mounted by battery
goodwrenchk29 is offline
post #2 of 3 Old 03-04-2013, 04:47 PM Thread Starter
goodwrenchk29
the main difference i see is that the holes for the ac lines are drilled beside the gas pedal instead of under the heater core inlet that you see in aftermarket systems. the evap support bracket holes are also punched and threaded instead of self tapping screws. any help will be appreciated.
pics will be wonderfull
post #3 of 3 Old 03-05-2013, 05:03 PM Thread Starter
goodwrenchk29
