1990 Wrangler YJ 2.5 liter with TBI --What Next? - JeepForum.com
post #1 of 11 Old 09-12-2013, 12:02 AM Thread Starter
Calpastor
Started stalling, backfiring, idling rough...
I changed plugs, wires, cap, rotor - No change
New Battery - No change
New coil - No change
New Fuel Pump and Filter - No change
New Crank Position Sensor - No change
Calpastor is offline
post #2 of 11 Old 09-12-2013, 05:43 AM
Que89YJ
Does it make any difference in the way it runs hot or cold?
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #3 of 11 Old 09-13-2013, 11:24 PM Thread Starter
Calpastor
Cold runs better...but warms quickly and then runs bad...
I replaced throttle body injector today - No change
What's this part?
post #4 of 11 Old 09-14-2013, 12:46 AM
ShArKtRaInEr
Check for vacuum leaks, like behind the engine where the trans meets. There is a junction there. Also you can check the oxygen sensor and throttle position switch at the back of the throttle body.
That photo is the idle speed motor. You can reset/retract it with a little 9V battery, the two center pins are where you connect after disconnecting the harness.
ShArKtRaInEr is offline
post #5 of 11 Old 09-14-2013, 04:52 AM
Que89YJ
If there is a big difference hot to cold then o2 or coolant temp sensor. Not the one for the guage. Can't figure out where you took the pic?
Fault codes:
No Start:
Que89YJ is offline
post #6 of 11 Old 09-14-2013, 10:49 AM Thread Starter
Calpastor
Not a big difference hot to cold.
I do have an exhaust leak...could that cause the proble?
I may replace TPS today...what about EGR? Could that creat idle issues?
Pic was Idle Control Motor
post #7 of 11 Old 09-14-2013, 10:47 PM Thread Starter
Calpastor
Added new throttle position sensor - still rough idle
I have an exhaust leak on exhaust manifold...couple bolts missing, could that create a vacuum leak?
I'm also wondering about EGR valve, but it's about 110 to replace. Ouch!
post #8 of 11 Old 09-14-2013, 11:52 PM
Que89YJ
The exhaust leak is throwing off the o2 sensor causing you to run rich and throwing off the calibration. On the pre 91 yj there is a setup procedure that must be done for the tps, ais, and wot when replacing.
Fault codes:
No Start:
Que89YJ is offline
post #9 of 11 Old 09-16-2013, 12:09 AM Thread Starter
Calpastor
I'll update after that.
post #10 of 11 Old 09-30-2013, 09:21 PM Thread Starter
Calpastor
Ok...
Feeling dumb, and angry.
Bad Spark Plug! Not cracked, not broken. I changed plugs, wires, rotor, and cap when my engine started running rough. And it didn't help. My mechanic removed plugs and tested them and found one that just was a dud. Running like a champ now!
post #11 of 11 Old 09-30-2013, 09:59 PM
Chrisnvegas
Chrisnvegas's Avatar
That was one expensive spark plug!
"Get off my lawn"
Chrisnvegas is offline
