-   -   1990 Wrangler YJ 2.5 liter with TBI --What Next? (http://www.jeepforum.com/forum/f12/1990-wrangler-yj-2-5-liter-tbi-what-next-1577777/)
Calpastor 09-12-2013 12:02 AM
Started stalling, backfiring, idling rough...
I changed plugs, wires, cap, rotor - No change
New Battery - No change
New coil - No change
New Fuel Pump and Filter - No change
New Crank Position Sensor - No change
Que89YJ 09-12-2013 05:43 AM
Does it make any difference in the way it runs hot or cold?
Calpastor 09-13-2013 11:24 PM
1 Attachment(s)
Cold runs better...but warms quickly and then runs bad...
I replaced throttle body injector today - No change
What's this part?
Attachment 674721
ShArKtRaInEr 09-14-2013 12:46 AM
Check for vacuum leaks, like behind the engine where the trans meets. There is a junction there. Also you can check the oxygen sensor and throttle position switch at the back of the throttle body.
That photo is the idle speed motor. You can reset/retract it with a little 9V battery, the two center pins are where you connect after disconnecting the harness.
Que89YJ 09-14-2013 04:52 AM
If there is a big difference hot to cold then o2 or coolant temp sensor. Not the one for the guage. Can't figure out where you took the pic?
Calpastor 09-14-2013 10:49 AM
Not a big difference hot to cold.
I do have an exhaust leak...could that cause the proble?
I may replace TPS today...what about EGR? Could that creat idle issues?
Pic was Idle Control Motor
Calpastor 09-14-2013 10:47 PM
Added new throttle position sensor - still rough idle
I have an exhaust leak on exhaust manifold...couple bolts missing, could that create a vacuum leak?
I'm also wondering about EGR valve, but it's about 110 to replace. Ouch!
Que89YJ 09-14-2013 11:52 PM
The exhaust leak is throwing off the o2 sensor causing you to run rich and throwing off the calibration. On the pre 91 yj there is a setup procedure that must be done for the tps, ais, and wot when replacing.
Calpastor 09-16-2013 12:09 AM
I'll update after that.
Calpastor 09-30-2013 09:21 PM
Ok...
Feeling dumb, and angry.
Bad Spark Plug! Not cracked, not broken. I changed plugs, wires, rotor, and cap when my engine started running rough. And it didn't help. My mechanic removed plugs and tested them and found one that just was a dud. Running like a champ now!
Chrisnvegas 09-30-2013 09:59 PM
That was one expensive spark plug!
The time now is 07:31 PM.
