1990 Wrangler 4.2L Timing Help - Page 3 - JeepForum.com
post #31 of 42 Old 05-14-2010, 08:26 PM
Old4X
1990 CJ7
Originally Posted by yellow2kgt View Post
On the timing issue.. If is the original balancer it could have slipped. It obviously sounds like you have other issues with low vacuum not running right. However, I had a problem with not being able to set the timing with a light. When I tried the mark was about 60 degrees off. I just set it by ear and it ran great. Come to find out the outside of the balancer had walked. A new balancer was installed and the timing marks are now where they should be.
Come to think of it, I had a Chevy truck with a slipped harmonic balancer. I would advance the timing till it would ping under a light load, then back it off a few degrees. Ran it like that for 20 years.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #32 of 42 Old 05-14-2010, 08:28 PM
CSCmrwizard
1982 CJ5
Originally Posted by hubb6666 View Post
Offenhauser is off!
so what you want for the carb
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #33 of 42 Old 05-14-2010, 08:32 PM Thread Starter
hubb6666
$500 for the carb and intake.
hubb6666 is offline
post #34 of 42 Old 05-15-2010, 11:52 AM Thread Starter
hubb6666
Just wanted to say thanks to everyone. After installing the Stock Intake, Weber Conversion Kit and Holley Regulator my Jeep now runs good, vacuum is at 20 and my timing is dead on 9 degrees. I guess there must have been some sort of vacuum problem causing my timing to be way off. As you can see in the pics I didn't hook up the heater hoses going to the intake because Advanced Auto said they don't show any heater hoses going to the intake.
hubb6666 is offline
post #35 of 42 Old 05-15-2010, 01:02 PM
timatoe
timatoe's Avatar
They're wrong, but you probably won't notice any issues throughout summer, but it could be an issue in winter. You don't have to have any preformed hoses there, just standard old heater hose will work.
Glad to see that you've got it all going.
timatoe is offline
post #36 of 42 Old 05-15-2010, 02:58 PM
Yarz
They probably didn't show them because they're a discontinued part.. You've got to make something else work if you want them. There's a thread around here somewhere about it..
Edit: Here it is: http://www.jeepforum.com/forum/f12/c...-help-1013422/
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life."
1990 White YJ TBI350, SM465, NP231, SOA, RE 1.5" SOA springs, Ford 8.8, D30, 4.10's, JBConversions SYE, XJ shaft, Bilstein 5150s, jb4x4 steering, MORE SS brakelines, 35x12.50 15 MT's, '95 YJ Brake Booster, '78 Grand Marquis MC, ZJ Prop. Valve
Yarz is offline
post #37 of 42 Old 05-15-2010, 03:20 PM
dtn8tr
The heater hose that you have connected to the water neck should be connected to the rear of the intake manifold and then you should connect a 5/8" heat hose from the waterneck to the front of the manifold.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #38 of 42 Old 05-15-2010, 07:59 PM Thread Starter
hubb6666
The weird thing about mine is the water neck is around 3/4" and the intake is 5/8". Hey Yarz thanks for the link.
hubb6666 is offline
post #39 of 42 Old 05-15-2010, 08:06 PM
dtn8tr
I know it's tight. I bought 8 feet of 5/8" yesterday because the hose from the waterneck to the manifold is the one that I took with me to NAPA and was going to replace all of it. Turns out that the hose from the heater core back to the water pump needs to be bigger...didn't check the other connection from the core to the back of the manifold yet but I know that the5/8' will go on the manifold to water neck.
dtn8tr is offline
post #40 of 42 Old 05-15-2010, 08:20 PM Thread Starter
hubb6666
I'll see if I can get it on there tomorrow.
hubb6666 is offline
post #41 of 42 Old 05-16-2010, 12:58 AM
Fernando
Fernando's Avatar
1987 YJ Wrangler
Glad to see you got it running!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is online now
post #42 of 42 Old 05-16-2010, 03:51 PM Thread Starter
hubb6666
Thanks Fernando.
hubb6666 is offline
New (to me) 1990 Wrangler JcJamez YJ Wrangler Technical Forum 6 03-04-2009 05:08 AM
New to me 1990 wrangler... KFalc YJ Wrangler Technical Forum 4 01-02-2008 10:35 PM
1990 wrangler XJ ? YJames90 YJ Wrangler Technical Forum 7 09-01-2007 09:43 PM
1990 wrangler mtwallace14 YJ Wrangler Technical Forum 2 05-20-2006 09:05 PM
1990 Wrangler oct7brian YJ Wrangler Technical Forum 8 10-04-2004 12:20 AM
