1990 TF999 computer controlled? - JeepForum.com
post #1 of 5 Old 04-18-2010, 06:29 PM Thread Starter
stickfight
I searched around and didn't find anything definitive. I have a 1990 YJ with an automatic.
Now that I have both an MC 2100 and a CRT HEI, and the associated electrical changes, is my computer controlling anything? The only thing I can imagine is my trans. I'd like to pull the computer and associated wiring harnesses to clean things up.
stickfight is offline
post #2 of 5 Old 04-18-2010, 06:34 PM
Mark05059
You can ditch the computer...
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 04-18-2010, 06:37 PM
Burnerman
Burnerman's Avatar
The trans is not controlled by any computer. There are 3 or 4 wires to it for the reverse lights and neutral safety switch.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #4 of 5 Old 04-18-2010, 06:54 PM Thread Starter
stickfight
Beautiful....thanks for the quick responses.
post #5 of 5 Old 04-18-2010, 08:23 PM
MoparFreak69
Exactly as Burnerman said. There isnt anything electrical on that trans except neutral safety and reverse lights. Delete wiring/controller as you see fit.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
JK Braking, computer controlled? badgerking JK Wrangler Technical Forum 1 01-03-2010 08:50 PM
V8 swap - wiring around the computer controlled AC Giviner TJ Wrangler Technical Forum 0 11-30-2009 07:14 PM
1990 Yj 2.5L where is the computer located? redlineblues YJ Wrangler Technical Forum 10 01-06-2009 05:46 PM
1990 YJ does it have a Computer? redlineblues YJ Wrangler Technical Forum 9 01-06-2009 05:02 PM
computer controlled carb? travis88yj YJ Wrangler Technical Forum 1 10-25-2004 12:31 PM
