1990 Jeep wrangler YJ Solenoid wire? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 1990 Jeep wrangler YJ Solenoid wire?
Poison Spyder from CCOR!REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 08-01-2008, 08:13 PM   #1
jake18
Hi i just bough a 1990 jeep wrangler yj. It has a 4.2 in it with a carter bbd carberator. There were many loose wire hanging down and we found the homes for them except one green and black wire that is conneted to the solenoid on the carberater. It is connected to the solenoid on one side and cut and hanging near the gas pedal now. I have no clue what this is for and in desparate need of your knowledge. Thanks
jake18 is offline   Reply With Quote
Unread 08-01-2008, 10:04 PM   #2
Burnerman
Is the soliniod by the throttle linkage on the carb? The other end is cut and dangling inside the Jeep by the gas pedal? The only thing I could think of is it was a idle kick up for aftermarket A/C. Pictures would help.
[SIZE="3"]89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
[/SIZE]
Check my Gallery for pics.
[URL="http://www.jeepforum.com/forum/f12/my-unbuild-rebuild-988762/"]My Rebuild Thread[/URL]
[SIZE="2"][COLOR="Blue"]Take a minute and fill out your profile, Please[/COLOR][/SIZE]
Burnerman is offline   Reply With Quote
Unread 08-02-2008, 06:23 AM   #3
kloppk
If it's the solenoid on the front of the carb then it's the idle solenoid.
It's normally controlled by the MCU to increase your RPM's a few hundred under certain conditions. It's fed by the MCU (behind the glove box wich in turn passes the signal thru the diode/fuze assembly and then on to the idle solenoid. The idle solenoid also has a vacuum hose going to it too.
http://home.sprynet.com/~dale02/solvac.htm
I the soenoid you are referring to is on the back of the carb then it's the stepper motor. It's wired directly to the MCU behind the glove box.
http://home.sprynet.com/~dale02/major.htm#init
You can get on-line schematics at the Autozone website.
Drill down in the "Repair Info" section on the left to get them.
kloppk is offline   Reply With Quote
