1990 4.2 weber fuel pressure issues - JeepForum.com
post #1 of 8 Old 05-23-2009, 01:39 PM Thread Starter
tippmann243
so i have had my weber installed for about a year, havent had any issues with it the whole time.
yesterday i noticed i had an oil leak when i was leaving work. it wasnt bad so i proceded to drive home. i got home and started rooting around under the hood to see if i could locate the leak. turns out its a valve cover gasket.
while i was under the hood i noticed my fuel pressure gauge was acting funny.
here is a video of what it was doing.
when i installed the carb and pressure reg it fluttered a little bit. maybe about 1/8-1/4 of a psi. im not to savvy with carbs but i assumed this was some what normal and it wasnt a drastic change so i went about my business.
also i tried to adjust the pressure on my reg and it would not change if i went 100% open. it still jumped from 0-2psi.
it runs great. starts the first time every time. never had any vapor lock issues.
is this a sign that my fuel pump is going bad?
89 blazer, L31/t56 28mpg.
blazer video,
1990 jeep, 4.2, 5speed.
tippmann243 is offline
post #2 of 8 Old 05-23-2009, 02:30 PM
Jeepsr4me19
1976 CJ5
clogged filter will do it too. Or a bad gauge.
Jeepsr4me19 is offline
post #3 of 8 Old 05-23-2009, 02:36 PM Thread Starter
tippmann243
filter is only about a month old. i replaced that last time i changed the oil.
if you put your hand on the fuel pump you can "feel" it working. everytime that lobe comes over and works the pump you can feel it. every time this happens the gauge jumps to 2psi.
this is why i was wondering if it was a bad pump. maybe the diaphram is going bad or something?
blazer video,
post #4 of 8 Old 05-23-2009, 03:30 PM
Jeepsr4me19
1976 CJ5
pump is cheap and easy to replace. Might as well change it. But a pump that is working hard to pull fuel will also do it. Filter can get clogged in a short period of time. I had a test chart on how much fuel a manual pump can move. You take the hose off and put in a bottle and crank the engine for only 10 seconds. It would fill about 1/2 way on a coke bottle.
post #5 of 8 Old 05-23-2009, 03:32 PM Thread Starter
tippmann243
so about 8 ounces of gas in 10 seconds for a mechanical pump.
thats en easy enough test. i will do that tomorrow when i install my valve cover gasket
blazer video,
post #6 of 8 Old 05-23-2009, 06:14 PM
dbikers
hey tippman...
mine is exactly the same...i thought it was the fuel pump..now i have a brand new pump, no fpr, and it does exactly the same thing.
i don't know what to make of it but really don't have any problems with it
STUPID HURTS.......OUCH!@#$
dbikers is offline
post #7 of 8 Old 05-23-2009, 06:24 PM
Jeepsr4me19
1976 CJ5
I just had this same problem on my VW dune buggy. the needle bounced around like crazy. But my pump is electric, and I could hear it running. I replaced the filter and bam solid 7psi. It would even pump a bunch out using the test, but not under pressure.
post #8 of 8 Old 05-23-2009, 07:07 PM Thread Starter
tippmann243
maybe i just got some junk in the filter.
filter is cheeper to replace so i will try that first when i do my valve cover gasket tomorrow.
blazer video,
recomended fuel pressure weber 34 bob_90yj YJ Wrangler Technical Forum 6 02-22-2010 06:38 PM
Fuel Pressure Regulator For Weber? Initial timing? tclaremont Wrangler General Discussion 0 08-04-2009 04:23 PM
Installing weber 34 carb, Fuel pressure reg installed rustywrangler YJ Wrangler Technical Forum 57 04-27-2009 02:21 PM
Fuel Pressure with the Weber holmes133 YJ Wrangler Technical Forum 6 07-06-2003 06:12 PM
weber / fuel pressure regulator turfman* YJ Wrangler Technical Forum 0 11-30-2002 11:06 AM
