1990 4.2 tick - JeepForum.com
post #1 of 7 Old 03-23-2013, 07:13 PM Thread Starter
FOXXX0126
1990 4.2 tick
I've been having issues with a very elusive tick coming from my engine. it ticks sporadically at idle and consistently under load. I've pulled the water pump, checked the fins and bearings, and that wasn't the issue. i pulled the harmonic ballancer and timing cover to check that it wasn't an issue with the timing chain, it wasn't. as i was putting everything back on, i noticed the negative battery cable to the block was not tightened down all the way. could this cause a ticking sound?
Built Not Bought #704
FOXXX0126 is offline
post #2 of 7 Old 03-23-2013, 07:39 PM
CB10101
It could be if its arcing. If you're sure its on that side of the block and not an exhaust leak. Also check your spark plug boots. The insulation can wear out on cheap wires and jump through the boot to your head. If you check at night, in the dark, you'll see sparks.
CB10101 is offline
post #3 of 7 Old 03-23-2013, 07:47 PM Thread Starter
FOXXX0126
the plug wires are brand new and so are the plugs. ill tighten down the bolt to the block and see if that changes anything
post #4 of 7 Old 04-04-2013, 09:29 PM
gsnfl
Any luck? I'm fighting a similar demon. Drive shaft u-joints?
gsnfl is offline
post #5 of 7 Old 04-05-2013, 03:33 AM
JCashen
Check everything even if it doesn't seem like it has anything to do with your problem.
I had noises from the rear every time I took off or shifted. I thought well differential or u-joints. Turned out the u-bolts on the leaf springs wiggled loose, quickly tightened them up and the noise went away.
"Drippy"
90 YJ 5.2 Magnum MS3x, D60/GM 10.5", ORI struts, 4 link
JCashen is offline
post #6 of 7 Old 04-05-2013, 05:16 AM
roadyrob
1987 YJ Wrangler
try to pin point the noise with a piece of garden hose or mech stethyscope. I had one that about drove me crazy finding, turned out to be the power steering belt.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #7 of 7 Old 04-05-2013, 11:02 PM Thread Starter
FOXXX0126
I've narrowed it down to the transmission. I've gotten my hands on a new to me ax15 that ill be rebuilding to swap the old one out. if you've had you're clutch off recently make sure you've put it on the right direction, I've heard if its on backwards the springs will catch the bolts on the fly wheel and create such a ticking noise.
