1990 2.5 Valve Cover Aluminum? - JeepForum.com
post #1 of 6 Old 01-04-2011, 05:51 PM Thread Starter
scottthomp
I have a '90 with the plastic valve cover. I recently replaced the gasket, but the cover is cracked in many places and is leaking bad. Can this be replaced with the later 91-95 aluminum style valve cover? I know i will have to re-run the pcv valve line, but i want to know if it will bolt down. Mine has a lot of blow by and it blows out of the crappy plastic oil fill cap. I would like the aluminum cover for the better screw on cap as well as the better ability to seal off. I am tired of smelling burnt oil, but i refuse to rebuild the engine as it runs just fine.
scottthomp is offline
post #2 of 6 Old 01-04-2011, 07:43 PM
SDGBASSE
It bolts on perfectly, the engine are the same, only the accessories are different.
Edit: I'm not 100% positive if the screws are the same, the 91-95 might have a longer shank....
Originally Posted by ZeroGravity View Post
I didn't click the link because it says "power probe" in the url.
SDGBASSE is offline
post #3 of 6 Old 01-04-2011, 07:50 PM Thread Starter
scottthomp
Will i have to convert the ccv system to pcv? Is that as simple as removing the existing grommet and putting in the pcv grommet?
post #4 of 6 Old 01-04-2011, 07:56 PM
SDGBASSE
No idea, I dropped the project at that point, hopefully you'll have more time than me to find the answer and will post it here so I can do the same!
SDGBASSE is offline
post #5 of 6 Old 01-05-2011, 01:25 PM Thread Starter
scottthomp
I have one on the way. I will take a look at it when it gets here and see if it is possible. I will post on here if it works and solves the leaking problem. Thanks
post #6 of 6 Old 06-21-2012, 05:25 PM
akbrian
Do you have an update? I'm considering replacing my plastic 90 2.5L YJ with a 91 style OEM aluminum one and wonder how hard it is to deal with the different crankcase ventilation system. I sure like the idea of a screw on oil fill cap over the leaky 1/4 turn style my 90 has.
akbrian is offline
2.5 aluminum valve cover badazzpolaris YJ Wrangler Technical Forum 6 03-18-2017 06:29 PM
Aluminum Valve Cover 4-cyl Travisrp TJ Wrangler Technical Forum 0 08-27-2008 08:43 PM
2.5L Aluminum Valve cover? 1stJeepyj YJ Wrangler Technical Forum 6 12-17-2006 10:13 AM
Aluminum valve cover todnshay YJ Wrangler Technical Forum 5 06-15-2004 08:49 PM
So i got an Aluminum Valve Cover for my 87'.... 83iS YJ Wrangler Technical Forum 4 04-03-2004 09:15 PM
